xolo a500s lite back light problem...... Xolo a500s lite......display light to low i change the lcd and coils also same problem plz help me forum....... |
downloads software 100% ok |
Its hardware bro not software |
first check its water damage or clean.. if water damage than try to clean lcd connector and check any pins break or not.. if all ok than try to change coil, 6 leg ic, and diode... hope your problem will be solved.... Purshottam |
But I Have Display Ic Problem Where is it In PCB Brother Please Show Display Ic With Picture File Please help Brother ....... |
check 6pin led transistor & coil |
every value is proper i change coil and diode and 6leg transistor bt not working............... |
Xolo a500 disply not show but set is on plz slov Plz send me xolo a500 pcd image or light jumper |
xolo a500s lite speaker jumper solution pls thanks in advance |
