Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Xolo
Old 05-12-2016, 11:16   #1 (permalink)
Absar_Global's Avatar
Member: 1442705
Thanks Meter: 1,061
Xolo Era 4G FRP Lock Solution [Available]
Xolo Era 4g Frp Lock 100% Solution
Flash File-
Flash Tool-
The Following 5 Users Say Thank You to Absar_Global For This Useful Post:
Old 06-09-2016, 06:23   #2 (permalink)
Member: 2573249
Thanks Meter: 2
sir plz give the flash tool...plz
The Following User Says Thank You to vivek786 For This Useful Post:
Old 11-12-2016, 09:44   #3 (permalink)
Member: 1691493
thanks it worked
100%
Old 11-15-2016, 10:36   #4 (permalink)
Member: 2614987
Thanks Meter: 5
xolo era 4g frp reset solved
if u have cm2 tool,select cpu sc9830 in spd software
and reset frp
The Following 2 Users Say Thank You to sumitkansal For This Useful Post:
Old 12-10-2016, 14:34   #5 (permalink)
Member: 1340203
thanks for the file
i use SPD_Upgrade_Tool_R2.9.9015 for flashing
Old 12-27-2016, 13:54   #6 (permalink)
Member: 2663787
Sry pls send me scrren short
Old 02-05-2017, 12:50   #7 (permalink)
Member: 332025
Thanks Meter: 35
Thumbs up Xolo era 4g frp bypass done
XOLO ERA 4G FRP BYPASS DONE
Solution Here :- https://www.youtube.com/watch?v=41GzViiuf3w
Old 02-21-2017, 14:59   #8 (permalink)
Member: 1262484
Thanks Meter: 5
USE "Quick Shortcut Maker" Method.
100000000000% Solution Tested by me.
Old 03-09-2017, 16:02   #9 (permalink)
VIJAYMOURYA's Avatar
Member: 712406
Sonork: 100.1651933
Thanks Meter: 251
ALL SPD ANDROID UNLOCK BY FASTBOOT COMMANDS 100% WORKING AND EASY
https://www.youtube.com/watch?v=QhyC...ture=*********
Old 03-27-2017, 14:50   #10 (permalink)
deb kumar dhali's Avatar
Member: 2234421
Sonork: 100.1674816
Thanks Meter: 60
and reset frp
its work 100% for me
Old 08-28-2017, 11:07   #11 (permalink)
irfanboss's Avatar
Member: 256247
Thanks Meter: 444
and reset frp
Operation : Format File System / Reset Settings [ v1.26 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 4 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC9830 eMMC Generic Loader v2 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:19
Reconnect Power/Cable!
thaks
The Following User Says Thank You to irfanboss For This Useful Post:
Old 09-13-2017, 09:23   #12 (permalink)
Member: 2083746
thanks it worked
100% cm2 tool
Old 11-13-2018, 09:11   #13 (permalink)
babu lal saini's Avatar
Member: 1935677
Thanks Meter: 22
xolo ERA1XPRO FLASH FILE
Hello anybody
please upload xolo era1xpro tested frimware
i used the this framware file ( xolo era 1x s107 20160816 ) and set dead
please upload tested fraimware file
thanks in advance
Old 11-23-2018, 00:16   #14 (permalink)
Member: 2816318
Thanks Meter: 11
Originally Posted by babu lal saini View Post
Hello anybody
thanks in advance
Check Here-https://firmware-file.com/2018/10/31...-firmware-rom/
The Following User Says Thank You to jhonysins For This Useful Post:
Old 08-16-2019, 12:07   #15 (permalink)
Member: 1710210
Thanks Meter: 35
Xolo ERA 4X 1GB FRP SUCCESSFULY REMOVED
https://*********/4Fs3vaUltBA
Page generated in 0.21774 seconds with 8 queries
