12-12-2014, 03:25 | #2 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2307081 Status: Offline Thanks Meter: 0 | Hello everyone , I am totally bricked my q1000 opus2. firmware already downloaded , need the flashing tool which is working on win7. I am taking backup from stock recovery but it can't restore . Flashing system,data, boot,recovery in fast boot mode,but going in boot loop. So pls. Pls. Help me. |
12-14-2014, 09:03 | #3 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | https://drive.google.com/file/d/0B1H...ew?usp=sharing This is the downloaded for this model : if you have problems on win 7, just run it as administrator. BR Alex |
The Following 2 Users Say Thank You to moulnisky For This Useful Post: |
12-15-2014, 02:33 | #4 (permalink) |
Member: 2307081 Status: Offline Thanks Meter: 0 | Thank you br Alex HW_onekey downloader not work properly evenly run as administrator, i can't select path for file to flash and can't see the connected phone.I think phone partition has been totally wiped,error in fastboot mode "partition table dosen't exist". In recovery mode , " can't mount path partition formated". adb sideload work but can't push the file to internal partition. I think its totally bricked,no chance to recover. If any solution to recover pls. help. |
12-16-2014, 09:19 | #5 (permalink) | |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Quote:
Normally this happens when someone format the mobile under windows when the boot area is getting seen as external drive. BR Alex Last edited by moulnisky; 12-17-2014 at 09:14. Reason: Spelling | |
07-19-2016, 14:16 | #7 (permalink) |
No Life Poster Join Date: Dec 2008 Location: GUJARAT-INDIA
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | i have got solution solution for this tool because if you are not install a proper usb driver this tool not detect a phone please use yep usb drivers and do not press or hold any key for boot just a connect normal usb cable to phone |
