XOLO Q1100 IMEI NULL After Flash Please friends and experts i have a XOLO Q1100 which is come to me for forgot security password....i try to reset but every time demanding password so i flashed it and after flash IMEI NULL ....now what can i do ....how to rebuild OR get back......please any solution need urgentely |
I am facing the same problem. but i managed to get one of the two imei no. using efs professional tool. |
Procedure to use efs professional tool Please explain how to do this.........with efs professional tool.... i need it badely please urgent |
Hello, can you tell me cpu of phone and which firmware you used to flash ? and software details from the backside of phone ? |
download efs professional(google it). Install all the drivers of the phone in your computer. connect your phone to pc and open efs pro. go to qualcomm nv tools. there select your com port by checking in device manager. Mine was com4. Then click connect. go to secure ops tab. there check the imei box and write your imei no. Select target phone. now click write. it will give a confirmation msg. Thats it. But it is for only imei1 but imei2 is still unkown. |
Xolo q1100 ic = msm8228 |
Restore your IMEI 1 and IMEI 2 (No Signal Fix)(Invalid IMEI) 1. Dial *#*#3646633#*#* (EngineerMode) 2. Swipe from right to left once. 3. In Connectivity Tab Press CDS Information 4. Press Radio Information 5. In Phone Information tab and Press Phone 2 and type/add EMGR=1,10,"(YOUR IMEI 2 HERE)" and press SEND AT COMMAND. 6. Reboot 7. REPEAT Step 1-4 8. In Phone Information tab Enter Phone 1 and type/add EMGR=1,7,"(YOUR IMEI 1 HERE)" and press SEND AT COMMAND. 9. Reboot 10. To check if you have a valid IMEI dial *#06# Note: Follow the instructions carefully. Your IMEI 1 and IMEI 2 are indicated on the back of battery case. |
Xolo q1100 imei repaired!!!!!! I repaired the imei of xolo q1100. It was a very typical task but yet i am happy i repaired it myself!!! Contact me on +91XXXXXXXXXX to know how to repair imei of xolo q1100 or any phone having qualcomm chipset! |
xolo q1100 imei null success 100000% use this tool:GN_QC_EG_WRTIMEI_V1.2.0 - Download - 4shared |
xolo q1100 imei repair tool |
how can connect phone? with off mode or on mode? pls help |
how to use this tool off mode on mode how |
yes brother done this tool GN_QC_EG_WRTIMEI_V1.2.0 tested thksssssssss |
after flash xolo q1100 dead solution only show qualcomm hs usb qdloader 9008 any body help me urgent please.............. |
thanks its works but after enter wifi mac add |
