Xolo q2000L pattern lock, flashing failed!! Hi, I have one xolo q2000L , it has pattern lock , I try to flash but it stuck on 2% and stops , so I Disconnect the phone. And again when I try to flash, the flashing process stuck on 0% . http://i61.tinypic.com/2exonyt.jpg Need help. The phone doesn't turning on. |
Now When I flash with "Brcm_MultiDownloader_201" which is the original tool of this phone. http://i61.tinypic.com/21llrf5.jpg Phone turn on but LCD is in blue screen. Flashing completed only in 1 minutes but normally broadcom flashing takes approx,4 min http://i59.tinypic.com/35anl7p.jpg At first I mistakely flash with different flasher version v1.4.5.0 "Brcm_MultiDownloader v1.4.5.0 And the phone goes dead. Need help. |
me too this problem pls help Quote:
me too this problem pls help |
iam also face same problem after flash lcd blank |
Pls Use Xolo Q1000 Opus Tool And Post Result.,.. Because I Use Same File And XOLO Q1000 OPUS TOOL IN Q2000L NO ISSUE WITH DISPLAY.. Br Puneet5154 |
link for opus tool |
use to new multi tool 2.3 |
same problem iam use all version Toll no use display blank |
wat is this file ? pls replay |
please share file which u used . and flash tool |
xolo q2000l flash after blue screen |
same here i haven't got any solution ..please share if some one have |
same problem plzz help me any one have solution |
open rar file which u have download S017 Then open file in rar and rename only ill Q2000L and extract, then select file in broadcom tool 201 and flash, Done for me!!!!! |
