04-23-2015, 12:35 | #2 (permalink) |
Insane Poster Join Date: Jun 2009 Location: chennai
Member: 1054903 Status: Offline Thanks Meter: 4 | Celkon hard reset Unlock Cell phones From Boot Warning : While using this method all of the phone data will be deleted but it does not delete SD card data. It is preferred to remove SD card while performing hard reset. If the above method does not work then you this option will be handy. This option is also know as hard reset or factory restore settings. While performing this method please ensure that you have at least 50% of battery available in your cell phone. The method of hard reset are given below 1) Switch off your cell phone 2) Press the combine keys given below Volume Up + Camera button Volume Down + Power button Volume Up + Power button Volume Up + Home + Power button Volume Down + Volume Up + Power button Home + Camera button Home + Power button The above keys combinations are for every mobile brand try until you find the correct key combination. if any of the keys doesn’t work with your device then leave a message below with you mobile name and we will help you to reboot your device. 3) Release the button when the device power is on. android-recovery-factory-hard-reset 4) Now you are in Android Recovery System and see 4 different option. 5) To Scroll up don you have to press volume up button or volume down button 6) Select Wipe/Data Factory Reset 7) To confirm you want to erase data press the power button Now wait untill your cell phone is rebooting Last edited by Rahul_Bhutani; 04-26-2015 at 09:26. Reason: Website removed |
