My set also dead hang on logo position |
Go To Settings In Flash Tool -> Flash Operations -> Click On "Erase All Flash" -> Ok. Then Flash It. After Flash Repair IMEI Etc. Post Result Please. |
Require Intex aqua young, S/W Ver: 04 flashfile. |
volume + & connect usb cable with above tool working good |
How to imei write bro plz |
Use This Version IMEI Write Tool : WriteIMEI_R3.0.0001. Open Tool & Feel Both 15 Digits IMEI Then Click On "Write", Press & Holding Volume Down Key Insert USB Cable Then Insert Battery. Note : All Process Need To Do With In 30 Seconds, Otherwise IMEI Tool Stop & Need To Feel IMEI & Click On Write Again. Don't Release Volume Down Key Until You'll See "PASS!" & Green Color In IMEI Tool. Also Read Some Reference Threads From Beginning Please. http://forum.gsmhosting.com/vbb/f781...click-1672805/ http://forum.gsmhosting.com/vbb/f781...lable-1936252/ http://forum.gsmhosting.com/vbb/f781...r-pls-1936913/ http://forum.gsmhosting.com/vbb/f781...-tool-2080548/ |
thanks for all member who shearing the file an information |
AQUA YOUNG V07 stuck in user data......any one help me...i will try v05 also...help me pleaze....thanx.. |
If Your Cellphone Has Problem/Error Like Post No #18 Then Follow Solution Of Post No #19 Of Currently Thread. |
erase then flash baseband unknown i dont have nv |
How Did You "Erase" By Flash Tool? I Never Seen "Baseband Unknown" After "Erase" By Flash Tool. Yes, After "Erase" "Must" Need To Repair IMEI By IMEI Write Tool. Not Require NV File. |
this method is working my 3 handset dead problem solved thanks |
