Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Q-Mobile
Old 03-20-2013, 12:09   #1 (permalink)
Member: 453862
Thanks Meter: 53
Q Mobile E4 Charging Error
Please any body help me
i have Q Mobile E4 after a minute it show charging error.
It have Small 8 leg ic
i have done many china phones with fake or bad contact charging by jumpering with Diod.
but same
please help me with diagram.
Thanks
Old 04-18-2013, 09:12   #2 (permalink)
AMEERGUL's Avatar
Member: 669947
Sonork: 100.1614053
Thanks Meter: 157
wahhh kya answer dya hai change the charger and falut automaticaly solvew ho jaye ga
you know about this fault if your answer is no then why you write these lines if yes then help him but no about bad comments ok..........
Old 07-22-2013, 08:27   #3 (permalink)
Member: 1572648
Sonork: 100.1594828
Thanks Meter: 201
i have Same Problem
if any one have solution kindly post here
Old 07-22-2013, 15:18   #4 (permalink)
Member: 261042
answerchec thise ic chrarge and risetinse 0 and r220 thise ise soved any problem chrarge
Old 08-18-2013, 06:02   #5 (permalink)
Member: 1187507
Sonork: gullooo
Thanks Meter: 4
Q mobile e 4
daer i have same problem no body give us solution pleseeeeeeeeee help me
Old 08-23-2013, 11:09   #6 (permalink)
Member: 699117
Sonork: 1593976
Thanks Meter: 4,294,967,295
helo to all friends i face same problum.but i change the chrging bas problum is solved.i find the charging base in nokia 2700c 5130 etc 2700c usb jack u use as charging bas in many q mobile.becouse thise chr bas use in htc dsire hd.show u schematic soon.M.awais khan from rana mobile
Old 08-24-2013, 08:37   #7 (permalink)
reaj's Avatar
Member: 631470
Thanks Meter: 163
chr bas use ...........please give me a picture solution
Old 09-15-2013, 12:19   #8 (permalink)
Member: 2025487
I have same problum please help me ..........................
Old 09-15-2013, 14:09   #9 (permalink)
N.C.Erepola's Avatar
Member: 1615710
Sonork: 100.1647890
Thanks Meter: 238
but same
Thanks
Did you simply try another charger & Battery bro? if so Just change 8 leg charging IC from another board. Be careful when add jumper with diode it can overcharge your battery and damage to CPU and Power IC.
if you need some picture guides this thread will be help full.
http://forum.gsmhosting.com/vbb/f782...-save-1701749/
BR.
Old 06-30-2014, 15:49   #10 (permalink)
Member: 2214226
bro can any one help me about this problem
Old 11-19-2014, 09:40   #11 (permalink)
Member: 2014933
Sonork: 100.1640793
100%ok Qmobile E4 slutoion charging bais and power ic change
Old 11-30-2014, 10:18   #12 (permalink)
zoiya's Avatar
Member: 740220
Sonork: 100.1654997
Thanks Meter: 248
same problem qmobile g200 any solution
Old 12-01-2014, 17:55   #13 (permalink)
..:\\lucky//:..'s Avatar
Member: 1864000
Thanks Meter: 2,893
Change charging ic only and use good charger all will be fine.
Old 12-31-2014, 07:45   #14 (permalink)
Registered User
Member: 372459
only chang bsi line 1 rejsten 10k chang it bad charger and over volta age ererr
Old 03-09-2015, 11:18   #15 (permalink)
Member: 1200191
qmobile g200 mic ways solution plezzzzz
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.24487 seconds with 7 queries
