11-11-2019, 16:31 | #1 (permalink) |
Freak Poster Join Date: Nov 2011 Location: Bahawal nager pakistan
Member: 1698141 Status: Offline Sonork: 1617901 Thanks Meter: 155 | QMobile QSmart LT200 SP9850KA Flash File Read With Cm2 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : QMobile : HD Plus Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Device info : Patch Level : OPM2.171019.012 Display ID : QSmartLT200_MP_10_04 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-04-01 Build Time : 1555346404 Product Model : LT200 Product Brand : QSmart Product Name : LT200 Product Device : LT200 Product Manfct : QMobile Product Info : LT200 Product Board : sp9850ka_1h10 Board Platform : sp9850ka VlnrLevel : 0x00 SP9850KA__QMobile__LT200__8.1.0__QSmartLT200_MP_10 _04__OPM2.171019.012__LT200 Read : prodnv.img ExtSparse : Compression ratio : 19% Read : phase.cfg Read : recovery.img Read : tos.bin Read : sml.bin Read : u-boot.bin Read : boot_logo.bmp Read : fastboot_logo.bmp Read : nvitem_l.bin Make : persist.img Read : modem_wcn.img Read : modem_l.bin Read : deltanv_l.bin Read : gdsp_l.bin Read : ldsp_l.bin Read : pm_sys.bin Read : boot.img Read : system.img ExtSparse : Compression ratio : 90% Make : cache.img Read : vendor.img ExtSparse : Compression ratio : 54% Read : vbmeta.img Make : userdata.img Read : u-boot-spl.bin Firmware size : 0x67A9F7A0 ( 1.62 GiB ) Android Info saved : _Android_info.txt Reconnect Power/Cable! Free file for youtube subcribers YOUTUBE CCHANEL IDEALMOBILE DOWNLOAD |
The Following 4 Users Say Thank You to nasiraslam For This Useful Post: |
12-23-2019, 06:51 | #3 (permalink) | |
Freak Poster Join Date: Dec 2011 Location: pakistan
Member: 1703671 Status: Offline Sonork: 100.1627623 Thanks Meter: 26 | Quote:
12-23-2019, 06:55 | #4 (permalink) | |
The Following User Says Thank You to mustafa_thora For This Useful Post: |
06-10-2020, 07:02 | #13 (permalink) |
Freak Poster Join Date: Dec 2019 Location: multan
Member: 2940758 Status: Offline Thanks Meter: 12 | Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.05 Load IDBase v42913 Ok! Open : SPD_PROG.xml Reading package ... Read package finished! Created by Infinity-Box (c) 2019 Chinese Miracle II : Spreadtrum / UniSoc Service Module Device Info file : _Android_info.txt Patch Level : OPM2.171019.012 Display ID : QSmartLT200_MP_11_09 Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2019-08-05 Build Time : 1568205071 Product Model : LT200 Product Brand : QSmart Product Name : LT200 Product Device : LT200 Product Manfct : QMobile Product Info : LT200 Product Board : sp9850ka_1h10 Board Platform : sp9850ka Operation : Flash Firmware [ v2.05 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True Setting : WholeFLASH FORMAT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! ERROR : Protocol HandShake failed! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Flash Firmware [ v2.05 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True Setting : WholeFLASH FORMAT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : INFINITY FW PACKAGE Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... ERROR : FLASH FDL NOT started! Error : Fail to boot FDL! Unsupported device with selected fdl or settings! Change settings! Reconnect Power/Cable! Operation : Flash Firmware [ v2.05 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True Setting : WholeFLASH FORMAT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_2GB_SS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! ERASE : FORMAT WHOLE FLASH ... ERASE : FORMAT FLASH Completed! PMTMng : Skip update! Reason : untested chain! UBOOT : u-boot.bin Failed to update block! ERROR : 000000A2:84000000FF7B7E00 NVM : WRITE FAILED! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! Operation : Flash Firmware [ v2.05 ] Setting : Update NVRAM : False Setting : Force NVRAM : False Setting : Update PMT : True 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9850x_BASE : SC9850_eMMC_2GB_SS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! PMTMng : Skip update! Reason : untested chain! UBOOT : u-boot.bin Failed to update block! ERROR : 000000A2:84000000FF7B7E00 NVM : WRITE FAILED! Error : Flashing failed! Check previous message for more info! Reconnect Power/Cable! |
07-09-2020, 15:09 | #14 (permalink) |
No Life Poster Join Date: Jul 2009 Location: SINDH PAKISTAN
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | i6 metal 2018 frp wi6h great cm2 Operation : Format FS / Reset Settings [ v2.05 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:35 |
07-09-2020, 15:10 | #15 (permalink) |
Member: 1080718 Status: Offline Sonork: 100.1596539 QQ-2710826805 Thanks Meter: 2,247 | i6 metal 2018 frp with great cm2 Operation : Format FS / Reset Settings [ v2.05 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7731E_BASE : SC7731E_eMMC_1GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:35 |
