Lenovo General Lenovo phones discussion, firmwares, solution, help |
02-16-2018, 00:09 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | Okay, BEFORE BEGIN - CHARGE FULLY your device/tab !!! FOLLOW ALL STEPS CAREFULLY ! (Especially part with formatting) !!! All mistakes are made by you, and you only ! No one will warrant anything ! All goes on your responsibility! Now, lets make this guide as much simple as possible. - Download ROM, with all needed inside: TB4-7304I_S000041_171018_ROW - Unpack archive. pass: lenovo-forums.ru - Start SPFT, from unpacked folder \TB-7304I_S000041_171018_ROW\i-x_flash_tool\flash_tool.exe - Select DA Agent - DA_SWSEC.bin - Load scatter file from root folder \TB-7304I_S000041_171018_ROW\MT6737M_Android_scatter.txt - Main SPFT Window, go to drop-down menu "Options" - "Option" - "Download" - select both fields, close window - Main SPFT Window - Go to "Format" tab, select "Validation", "Manual format flash", copy/paste marked in red "Begin address" : 0x6a00000 , "Format length" : 0x100000 - Press "Start" button, connect powered off device to cable. - Wait for finish, green circle will be displayed (process goes fast - 4-7 seconds). - Enter device recovery, make "Wipe data/Factory reset", then "Reboot device". - FRP Should be gone. If you encounter "DL Image Failed" or "Tool DL failed" in bottom left corner, and reboot, Simply reflash device with provided rom. (Same procedure, but you don't do any format, just from main window, Download button.) p.s. Check attached images if something not clear. They explain all. p.s.2 If you get some error like in THIS post, then also load authentication file in SPFT - "auth_sv5.auth" Now, try and post results. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 02-28-2018 at 17:09. Reason: fixed procedure |
The Following 8 Users Say Thank You to Brka For This Useful Post: |
02-24-2018, 22:18 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | By default, if booting don't go / error - you should change DA_Agent first ... 1) Try flashing full ROM first. (or just cache/userdata) - If that works, you're ready to go. 2) Pay attention that you need enabled "USB checksum" and "Storage Checksum" in SPFT. 3) SPFT used: Folder \TB-7304I_S000041_171018_ROW\i-x_flash_tool\flash_tool.exe 4) Load DA Agent - select DA_SWSEC.bin 5) Load scatter file from root folder \TB-7304I_S000041_171018_ROW\MT6737M_Android_scatter.txt 6) If don't work - load authentication file from folder - auth_sv5.auth 7) If you get "Tool DL Image" (or similar error on screen bottom left corner) after FRP, and/or tab rebooting, reflash again stock rom. (You can flash only CACHE.img, to fix "Tool DL error") Test and post results. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 02-28-2018 at 17:08. Reason: added more info |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
02-26-2018, 16:27 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: tampin malaysia Age: 61
Member: 117956 Status: Offline Thanks Meter: 115 | Thanks for fast reply , i-x_flash_tool\flash_tool.exe use DA_SWSEC.bin tick flash preloader cache only okay . But i cant success hard reset with vol up down key or both keys , so i not dare to do manual format 0x6a00000 / 0x100000 . Any safe suggestion ? |
02-27-2018, 02:31 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | Just do manual format ... be carefull about start address and length. After that flash cache and userdata, it's the same as manual hard reset. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
05-14-2018, 21:31 | #8 (permalink) |
No Life Poster Join Date: Jul 2017
Member: 2737570 Status: Offline Thanks Meter: 117 | lenovo tab model 7304i after remove frp stuck problem , Help plzz I gotl lenovo tab model 7304i Got goole account so i flash it with small file which is remove google . My tab now is stuck not working . When i want to flash it again PC can feel it but not starting to flash not giving me any error but when i flash another phone its working help Ur help will be highly appreciate it Last edited by Brka; 05-15-2018 at 14:59. Reason: Removed box stuff |
05-16-2018, 00:34 | #9 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,786 | Quote:
use flash file and flasher which is in same package. Settings are same as for FRP reset/format, only difference is that you need to flash firmware. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
