Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 09-14-2016, 15:51   #1 (permalink)
Abid Gabol's Avatar
Member: 2185050
Thanks Meter: 21
Lenovo A369i invalid IMEI help
It shows invalid IMEI. Please give me working link for its tool & also working firmware link. I found many links on google but downloading does not start
Old 09-14-2016, 16:55   #2 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
chik basband ok or baseband unknown then fix basband or basband ok then write imei 100% ok with any tool
Old 09-15-2016, 15:51   #3 (permalink)
Abid Gabol's Avatar
Member: 2185050
Thanks Meter: 21
How can i check baseband?
Old 09-15-2016, 20:39   #4 (permalink)
wafi95's Avatar
Member: 2621055
Sonork: 100.1675233
Thanks Meter: 144
for check basbend
go to
setting>>about phone>>basbend version
......first try to repair imei on tool free(mtk droid tool)*need root*
......second try box miracle or nck to force repair*you can found this box with crack on the internet if you not have*
and dont forget if you basband unknown you need fixed it
Old 09-15-2016, 23:25   #5 (permalink)
wafi95's Avatar
Member: 2621055
Sonork: 100.1675233
Thanks Meter: 144
Turn on your phone and enable usb depuqqing
Go to list mtk option on box an select repair imei
Enter the imei number and click start buttom
**You need root phoe**
You dont tell me ;;;what a baseband stute?????
The Following User Says Thank You to wafi95 For This Useful Post:
Old 09-16-2016, 15:57   #6 (permalink)
Abid Gabol's Avatar
Member: 2185050
Thanks Meter: 21
I think baseband is ok see here
Old 09-16-2016, 16:08   #7 (permalink)
Abid Gabol's Avatar
Member: 2185050
Thanks Meter: 21
But inspite of unknown IMEI, BT address and IP address is also unavailable. See here
Old 09-16-2016, 16:10   #8 (permalink)
Abid Gabol's Avatar
Member: 2185050
Thanks Meter: 21
Old 09-16-2016, 18:52   #9 (permalink)
wafi95's Avatar
Member: 2621055
Sonork: 100.1675233
Thanks Meter: 144
To work on mtk droid tool:
1-enable usb debbug in phone..
2-root phone..
3-open mtk droid tool..
Then the ptogram show information phone..
4-after show information click root.
After that you show green color on the program (Down""left program)
5-after green color click repair to eneter imei..
After finish reboot you phone..
If you need any other help tell me...
This is program download ver 2.5.3 https://androidmtk.com/download-mtk-droid-tool
The Following 2 Users Say Thank You to wafi95 For This Useful Post:
Old 09-24-2016, 15:36   #10 (permalink)
Abid Gabol's Avatar
Member: 2185050
Thanks Meter: 21
Please only tell me that how to connect mobile with ******* because start button is not working i mean i'm unable to click on start button. Tell me full detail about connecting device with ******** & what should be usb mode?
Old 09-24-2016, 22:34   #11 (permalink)
wafi95's Avatar
Member: 2621055
Sonork: 100.1675233
Thanks Meter: 144
For start buttom you need to restor your date computer to 2015
And check the file handle.txt in your folder box in disk C..what the date in this file..
If the start buttom work okay but the ******* not see usb phone
Then problem in your computer..no solution becuase multi driver and box not offical..
**Note** if you cannot solution this problem you can use mtk driod tool for imei..
And use ******* box for read..write flash..
Old 09-24-2016, 22:51   #12 (permalink)
Abid Gabol's Avatar
Member: 2185050
Thanks Meter: 21
I am unable to repair imei with mtk droid tool and it is detecting mobile 100%
Old 09-25-2016, 08:15   #13 (permalink)
Registered User
Member: 2506300
Thanks Meter: 345
Bro try this ways 100% Solve Your Problem http://www.youtube.com/watch?v=C78RwG4bB8w
here Your DB file MT6572 - Download - 4shared - kamrol hasan
Old 09-25-2016, 16:39   #14 (permalink)
Abid Gabol's Avatar
Member: 2185050
Thanks Meter: 21
Please explain in detail that how to use DB file?
Old 10-12-2016, 09:50   #15 (permalink)
Abid Gabol's Avatar
Member: 2185050
Thanks Meter: 21
Helpppppppppppppppp me.................
Page generated in 0.23306 seconds with 8 queries
