Lenovo General Lenovo phones discussion, firmwares, solution, help |
11-28-2016, 10:12 | #3 (permalink) |
Junior Member Join Date: May 2016
Member: 2575429 Status: Offline Thanks Meter: 2 | Sometime when the baseband is unknown u have to change the emmc. Only that the best solution.... Sent from my GT-N7000 using Tapatalk |
The Following User Says Thank You to ApongFis For This Useful Post: |
12-22-2016, 17:33 | #9 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | I will post later nvram, it should solve imei/baseband. Last night i solved one 7020a48 with bad imei... B.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
02-28-2017, 00:21 | #11 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,786 | Quote:
b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 03-27-2017 at 23:47. Reason: added file | |
The Following 26 Users Say Thank You to Brka For This Useful Post: |
03-27-2017, 23:48 | #14 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,786 | I have added scatter file to my previous post. Put it in same folder as nvram file, Load it up in SPFlashTools, and flash it to phone. If you encounter "DL Image failed" on screen, just reflash phone. b.r. Alex
The Following 5 Users Say Thank You to Brka For This Useful Post: |
03-28-2017, 03:11 | #15 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | I will try ur scatter when im in shop. If im not wrong i edit scatter like u make, change its download to true and add file name or choose it manually. After flash i get dl image failed, i reflash phone after reboot always unknown baseband. |
The Following User Says Thank You to BouRRi_GSM For This Useful Post: |
