Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 11-26-2016, 07:52   #1 (permalink)
Member: 2496811
Thanks Meter: 6
Lenovo a7020a48 Baseband unknown, ROM
lenovo a7020a48 gaseband unknown
how to root any body help
Old 11-28-2016, 06:41   #2 (permalink)
Member: 2496811
Thanks Meter: 6
lenovo a7020a48 baseband unknown
lenovo a7020a48 baseband unknown pls any body help
how root
The Following User Says Thank You to sree mobiles For This Useful Post:
Old 11-28-2016, 10:12   #3 (permalink)
Member: 2575429
Thanks Meter: 2
Sometime when the baseband is unknown u have to change the emmc.
Only that the best solution....
Sent from my GT-N7000 using Tapatalk
The Following User Says Thank You to ApongFis For This Useful Post:
Old 11-30-2016, 18:19   #4 (permalink)
Member: 2655181
Thanks Meter: 4
Root is not possible.
Try use Adblock
Sent from my Lenovo A7020a48 using Tapatalk
The Following User Says Thank You to pcssandip21 For This Useful Post:
Old 12-17-2016, 11:56   #5 (permalink)
Member: 2496811
Thanks Meter: 6
how to Adb lock
how to Adb lock pls help for me
Old 12-17-2016, 12:53   #6 (permalink)
Member: 2655181
Thanks Meter: 4
Search on YouTube
Old 12-17-2016, 13:20   #7 (permalink)
Vahidpappali's Avatar
Member: 2602890
Sonork: NOTINSTALLED
Thanks Meter: 230
https://www.geekgyan.com/root-lenovo...-install-twrp/
do in your risk
The Following 2 Users Say Thank You to Vahidpappali For This Useful Post:
Old 12-18-2016, 06:56   #8 (permalink)
Member: 2655181
Thanks Meter: 4
Still TWRP commingled soon
The Following 2 Users Say Thank You to pcssandip21 For This Useful Post:
Old 12-22-2016, 17:33   #9 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
I will post later nvram, it should solve imei/baseband.
Last night i solved one 7020a48 with bad imei...
B.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 02-27-2017, 12:23   #10 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
B.r.
Alex
hello sir pls share ur nvram i have one same problem after flash
The Following 3 Users Say Thank You to akashub For This Useful Post:
Old 02-28-2017, 00:21   #11 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Attached.
b.r.
Alex
__________________
The Following 26 Users Say Thank You to Brka For This Useful Post:
Old 03-23-2017, 19:27   #12 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 648
Attached.
b.r.
Alex
Bro
Baseband problem solved after write this file?
The Following User Says Thank You to umarmsn For This Useful Post:
Old 03-27-2017, 21:59   #13 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
Attached.
b.r.
Alex
hello ,
how did u restore it?
The Following 2 Users Say Thank You to BouRRi_GSM For This Useful Post:
Old 03-27-2017, 23:48   #14 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Originally Posted by BouRRi_GSM View Post
hello ,
I have added scatter file to my previous post.
Put it in same folder as nvram file,
Load it up in SPFlashTools, and flash it to phone.
If you encounter "DL Image failed" on screen,
just reflash phone.
b.r.
Alex
__________________
The Following 5 Users Say Thank You to Brka For This Useful Post:
Old 03-28-2017, 03:11   #15 (permalink)
Registered User
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 967
just reflash phone.
b.r.
Alex
I will try ur scatter when im in shop. If im not wrong i edit scatter like u make, change its download to true and add file name or choose it manually. After flash i get dl image failed, i reflash phone after reboot always unknown baseband.
The Following User Says Thank You to BouRRi_GSM For This Useful Post:
Page generated in 0.22871 seconds with 9 queries
