Lenovo A850 Dead Boot Repair Without TP Lenovo A850 Dead Boot Repair Without TP http://drop.ndtv.com/TECH/product_da...novo-a850.jpeg HI Every One From Last 3Months i Searched many time About Lenovo A850 Dead Boot by Flashing After Flashing Set Goes Dead Mode and Just Red Light Blinking Not Other Function and also not detect PC i Found One Solution to open the Set and Connect TP that is Good Procedure Also But the Problem is need to open set and Clients dont want to open his phones Now When You Flash The Set then Always Use A850i Flash file when you use A850 Then Set will be Damage and Will Be Dead SOLUTION : Press Volume UP + Volume Down + PWR KEY Same Time Set will Be Connect Automatically And Flash Set By This Flash file A850_S121_28.11.2013_MULTI_LNG(ROW) or Lenovo_A850_4.2 & USB VCOM Driver Br WBGSM |
Link is alive working fine Thanks |
any one help me please my lenovo a706 just vibrating nothing else. when i connect the set with pc just the pc windows device connected sound i hear. i want to flash it. but i dont know how because it is not mtk chipset to flash it through sp-tool. please any one help ne thanks in advance |
my lenovo mobile A850 has not been flashed by sp tool there is showing pmt error when i am going to flash what i do any solution?? |
bro any other link. bcoz the link u have made i think its broken |
SP Flash Tool, format - ok, during flashing - error s_da_sdmmc_read_failed 3148. |
404. That’s an error. The requested URL was not found on this server. That’s all we know. Br - srinibas |
Lenovo A850 Volume Down Not Working Any Solution to fix problem??? |
I also flashed my Lenovo A850 with A850 firmware & it has dead. If i again flash with A850i will it recover? |
Yes boro when you flash a850i file your phone is recover and i am also tested |
Please give correct link to download |
Please give me correct link & working. I'm in trouble |
Hello boro This link is 100% ok file i am tested try is ok |
