Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 06-26-2018, 13:47   #1 (permalink)
Member: 2846953
Sonork: UK-wide
Lenovo k6 Power firmware needed
i nedd lenove k6 power firmware
Old 06-27-2018, 03:02   #2 (permalink)
Member: 2284034
Thanks Meter: 86
Download
Old 06-27-2018, 03:10   #3 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,827
As forum rules suggest (which you probably didn't read),
when posting is always good to put as much details as possible,
regarding your problem, device model, sub-model, software info, etc etc.
Now, regarding K6 Power - which one is yours ? K33a48, K33a42, etc. ?
Do you know which version was in the phone ?
Originally Posted by AndroidXDA View Post
Before user check his version of the phone, I don't suggest to flash anything.
It may be a different hardware version, and thus lead to permanent damage.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 04-10-2021, 10:30   #4 (permalink)
SOHAL ROCK's Avatar
Member: 1299776
Sonork: 100.1647203
Thanks Meter: 27
no solution is work only one solutions work that i descrived below
1. Flash the hand with the below flash file.
Link: File sharing and storage made simple
2.After Flash the handset switch on the mobile then you will get an system update complete the system update.
3. after that type ####682# then select county IN then set will restarted automatically after than volte will appear with any sim.
This is 100% working process and tested by me.
Old 04-10-2021, 22:02   #5 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,827
Originally Posted by SOHAL ROCK View Post
no solution is work only one solutions work that i descrived below ...
You missed the rom link
b.r
Alex
__________________
Page generated in 0.13169 seconds with 8 queries
