Lenovo General Lenovo phones discussion, firmwares, solution, help |
03-13-2017, 22:23 | #2 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
here's latest firmware (S040). A316i_S040_140730 Android 4.2.2 b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 6 Users Say Thank You to Brka For This Useful Post: |
03-15-2017, 11:21 | #3 (permalink) | |
Junior Member Join Date: Feb 2012
Member: 1724383 Status: Offline Thanks Meter: 0 | Quote:
you will know what I meant "Glode logo" , gsmhosting not allow me to post link yet. ================================================= the firmare you provided i think i already tested before. still got problem which cannot turn on. tested steps. - flashed firmware: 1) Lenovo_A316i_ROW_S034_140116 2) Lenovo_A316i_S040_140730 - format whole flash problem before flash stuck at lenovo logo problems after flash Can't turn on power No turn on vibration No charging animation - battery is ok - can detect when plugged in usb cable to pc. - sp flash tool - memory test emmc ok - can successfully flash the phone but won't turn on. anyone know what is the problem and how to fix this ? | |
03-15-2017, 23:14 | #5 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Dude ... it's GLOBE, not gloDe ... So, have you tested with flash file i posted earlier in this thread ? b.r. Alex
The Following 2 Users Say Thank You to Brka For This Useful Post: |
03-16-2017, 17:37 | #6 (permalink) | |
Yes. I have tested the firmware u posted in this thread, but no luck same as before after flashed can't turn on. any other way to fix it ? | |
03-16-2017, 17:41 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Yes. Reflash globe firmware, and after, Try flashing some other, without flashing preloader. Lets see what will happen. B.r. Alex
03-18-2017, 00:03 | #9 (permalink) | |
Thats all ... ******** EDIT : More info found ... I found that there are 2 different versions, and probably 2 different hardware. One is "normal" ROW model, and another is for Malaysia Region. Under that second model, there is GLOBE and MAXIS customized version of firmware ... So... you are tied to one of those two. Globe rom, you already have ... If you really want MAXIS rom ... well, i can upload, but its also customized. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! Last edited by Brka; 03-18-2017 at 00:22. Reason: added more info | |
The Following User Says Thank You to Brka For This Useful Post: |
03-20-2017, 02:46 | #11 (permalink) | |
Malaysia MAXIS archive pass : forum.gsmhosting.com test and post results. b.r. Alex
03-20-2017, 07:56 | #12 (permalink) |
Member: 1724383 Status: Offline Thanks Meter: 0 | tested, but still cannot boot up, no charging animation. still wrong firmware ? when I tick "DA DL All With Check Sum" get this message " BROM ERROR : S_CHKSUM ERROR(1041). can't finish the flash process Last edited by Brka; 03-20-2017 at 15:45. Reason: Merged posts |
03-20-2017, 15:48 | #13 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | We should shorten this whole thing... You have specific hardware a316i phone, It works with globe firmware only. Stick with it, and thats all. End of story. B.r Alex
03-20-2017, 19:50 | #14 (permalink) |
Member: 1724383 Status: Offline Thanks Meter: 0 | But I have tested all Globe version that found, non of those firmware is working. I found that there is another ver. on the net "Lenovo A316i 4.2.2 ALPS JB3 MP V130" downloaded but no password, so can't test. Do you have this version ? or anyone share it ? thanks. Last edited by mtk999999; 03-20-2017 at 19:56. |
03-20-2017, 22:59 | #15 (permalink) | |
I already lost a lot of time with this case, so i consider it finished. b.r. Alex
