Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 06-21-2017, 18:20   #31 (permalink)
bluejack22002's Avatar
Member: 741453
Thanks Meter: 41
can someone share with me Lenovo A766 nvram in .bin format? it give me error in adb with .img format.
Old 06-24-2017, 22:08   #32 (permalink)
Member: 2611622
a916 invalid imei after flashing
after I flash a916 with stock rom, I get invalid imei , also there no serial number , I try sn writer but I get error , maybe because the database files I get r not good , I try to root and write the imei by all the method I found on youtube but no success , does any one know to do it
Old 06-27-2017, 11:30   #33 (permalink)
Member: 2730974
Unhappy
I really need help Im from philippines after i flash my phone everything is ok except my network provider it has cignal but only emergency calls is display and i cant receive calls and text
I need help after i flash stockrom i think i need nvram for lenovo a1000 because my phone cant receive calls and text it has cgnal bars but status says only emergency call only and i did'nt backup my original firmware...
Old 06-28-2017, 11:47   #34 (permalink)
Dilip_Nath's Avatar
Member: 387110
Sonork: 100.1590892
Thanks Meter: 618
Originally Posted by pradyumnasahoo View Post
A2020a40 qcn file required..........
plz
Check this and post result bro.
***** EDIT by Mod:
Added xQCN + QCN File readed from 100% working A2020A40 Phone , DUAL-SIM,
for QPST (QPST Service Programming Module).
If you flashed phone with rawprogram_unsparse.xml
instead of rawprogram_unsparse_upgrade.xml,
and phone NOT showing imei at all (no any numbers),
First write "1_angus3_A6-50LNa_A2020a40_USR_S196_1705231927_Q8909_ROW.qcn"
with QPST (you must have enabled diagnostic port via box and rooted phone),
then reboot phone - imei numbers will appear.
Then, you can write either 2_a2020a40_qcn_brx.qcn or 2_a2020a40_qcn_brx.xqcn,
and reboot phone - imei should appear after flashing.
Edit .qcn file before writing for desired imei, or use free tools for writing,
google for it.
b.r.
Alex
File Type: rar A2020a40_Imei-NULL_FIX-repair_by_bRkA.rar (96.8 KB, 3090 views)
The Following 12 Users Say Thank You to Dilip_Nath For This Useful Post:
Old 06-29-2017, 09:56   #35 (permalink)
Member: 2611622
Flash nv, new imei
Hi. Lenovo a916 after new stock rom no imei. I flash nv file. New imei appear. But it s not the same on the back of the phone. I need to know if it s ok or i must change it to the imei that on the back. Because i am trying to but no success if i can leave it like that or i must change imei to work fine
Old 07-03-2017, 20:21   #36 (permalink)
Member: 1807834
Thanks Meter: 2
Hello sir..i need nvram backup for lenovo a3600d n a5600 ...urgent...thanks...
Old 07-04-2017, 20:04   #37 (permalink)
Member: 2732785
I am in dire need for the QCN of a Lenovo P2a42. I'd be so grateful!
Old 07-22-2017, 20:19   #38 (permalink)
Member: 2739458
Exclamation Need NVRAM for a7020a40 S318 161128 ROW
Guys,
I need nvram for a7020a40 S318 161128 ROW. Help please.
Thanks.
The Following User Says Thank You to nar3nd3r For This Useful Post:
Old 08-01-2017, 20:47   #39 (permalink)
Member: 1883473
Thanks Meter: 11
Please can u help me with Lenovo s850T nvram file ....after flashing phone network disappears...but sim card is detected
Old 08-01-2017, 23:50   #40 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,742
First, flash with correct firmware from HERE
(Use Chrome, Tampermonkey and BaiduPan script for TM + some download accelerator)
then write attached NVRAM via SPFT or BOX.
p.s. You can also try ROM's from HERE, but people report only 2G network working ...
Also reported to work rom - HERE
b.r.
Alex
File Type: rar s850t_MT6582_S00_S850T_S108_1_tg_n_eMMC.rar (9.3 KB, 74 views)
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 4 Users Say Thank You to Brka For This Useful Post:
Old 08-03-2017, 20:07   #41 (permalink)
Member: 1883473
Thanks Meter: 11
Thanks so much but this Lenovo s850 is different from Lenovo s850t....i flash Lenovo s850t successfully but no network and the sim is detected
Can u explain how to used the two attached file above please
The Following User Says Thank You to newjazzy For This Useful Post:
Old 08-03-2017, 20:57   #42 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,742
I posted you original rom and modifies rom's with radio module from T version.
Nvram is to be written with spflashtool
B.r.
Alex
__________________
Old 08-04-2017, 09:56   #43 (permalink)
Member: 1883473
Thanks Meter: 11
The download link u post is showing S850 but my Lenovo is S850t .... secondly what is function of the second file attached above
Old 08-04-2017, 22:50   #44 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,742
Just simply ignore my posts, if you don't like them, or don't understand what I wrote.
Also, I will ignore your posts in future.
No offense, at all
b.r.
Alex
__________________
Old 08-05-2017, 19:17   #45 (permalink)
Member: 1883473
Thanks Meter: 11
Engneer please ...am sorry to hurt u...thanks for your reply but this Lenovo have given me so much trouble and the customer is on my neck
The sim is detected but no network
Page generated in 0.21491 seconds with 8 queries
