Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 12-31-2019, 15:37   #1 (permalink)
Member: 2927780
Thanks Meter: 3
Lenovo P2 (P2a42) IMEI repair - expert advice :) needed
Hi!
I've been trying out many dongles to repair IMEI on this (admittedly old) lenovo phone.
So far, no dongles were successful in repairing the IMEI on Lenovo P2 (p2a42)
Perhaps someone more knowledgeable in this particular subforum can point me to a product that reliably works?
Old 12-31-2019, 19:39   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,822
In short (as possible)
- if phone is alive, unlock bootloader and install TWRP recovery
- Write Marsmallow ROM (ie: S062 version) (twrp firmware)
- check if baseband is okay under settings/about phone
- enable diag port via rooting (unlock bootloader, twrp, superSU etc.)
- write QCN file from THIS post
- reboot phone, imei should be there
- fix original imei via box or free tools (via diag port, or simply edit qcn file)
- if problems with 4G/LTE, erase modemst1, modemst2, rewrite qcn, fix imei.
p.s. Whole Process is a bit complicated, but you can obtain all info on google, 4PDA forum and lenovo-forums .ru
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 12-31-2019, 19:53   #3 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 953
Using this QCN backup you can repair your IMEI.
Too many guides for how to restore QCN files.
Diag code for your phone is ####8899#
P2a42_QCN
br, mshib0
The Following 3 Users Say Thank You to MiRoOo For This Useful Post:
Old 01-01-2020, 23:14   #4 (permalink)
Member: 2927780
Thanks Meter: 3
Hm, for some reason the QCN trick isn't working for me (I'm sure I did unlock bootloader, I did flash to Marshmallow ROM linked, I did make sure modem matches the marshmallow release)
There's a video that seems to suggest something called "EFS method" should be used
Old 01-05-2020, 22:18   #5 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,822
Okay, let me tell you again...
You dont need ANY dongle/box to repair imei on this device.
- after flashing the device, power it on
- CHECK IF THERE IS BASEBAND info present under settings/about device (should be displayed)
- imei should be empty (*#06#)
- Write QCN via QPST/Software Download module
- reboot device, check imei again, should be like: 358957060996039
Crucial thing is, that BASEBAND must appear.
b.r.
Alex
__________________
Old 02-14-2020, 18:30   #6 (permalink)
Member: 2927780
Thanks Meter: 3
b.r.
Alex
Hi Alex!
I suspect the subtle problem is that I want to CHANGE the imei on a phone with intact IMEI, and QCN restore does not over-write the old imei (so after reboot, the old imei returns)
Any pointers as to how to go about changing IMEI in case imei is initially intact (not empty)
P.S.:
currently trying out UMT dongle, no cigar so far...
Old 02-14-2020, 23:12   #7 (permalink)
Member: 2927780
Thanks Meter: 3
Oh, and I did try wiping modemst1, modemst2, then restoring the qcn. Still no cigar.
Page generated in 0.14531 seconds with 8 queries
