Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 03-05-2017, 15:29   #16 (permalink)
Member: 1965704
Thanks Meter: 2
LENOVO A Plus A1010a20 Root
How to root this phone?
The Following 2 Users Say Thank You to Sandi1987 For This Useful Post:
Old 03-06-2017, 22:36   #17 (permalink)
Member: 2692558
Smile Can't update my phone
Hi... How to download root for lenovo A606
The Following User Says Thank You to Hairul Azly For This Useful Post:
Old 03-08-2017, 03:30   #18 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,090
TWRP Recovery, download - HERE
You will need ADB Minimal (fastboot) for work.
Instructions :
- Copy the TWRP a folder where you unpacked ADB
- Reboot in fastboot - on powered on phone, with USB Debugging enabled, open command prompt in ADB folder, and type "adb reboot bootloader" or
on phone powered off, hold the volume up + power on.
Hold it until a menu appears - recovery, fastboot, normal.
Volume up switch the selection, volume down affirm.
- To flash TWRP - command : fastboot flash recovery TWRP_a1010.img
- Exit the fastboot and load into TWRP - press the volume up + power on
- Hold until a menu appears - fastboot, normal. Volume up switch the selection, volume down confirms
- After done, you will have custom recovery.
- Download SuperSU and put in phone internal memory or micro-SD card, put it in phone, and install from custom recovery (Install ZIP)
- After reboot, you will have ROOT.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 03-23-2017, 15:16   #19 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 566
how to root A6600a40 ver6.0 .........?
Old 04-01-2017, 19:28   #20 (permalink)
Member: 2700585
You want to root your Device?
For this you can also download one app,which will help to root your device, and that app name KingoRoot, try this.
Old 04-05-2017, 22:39   #21 (permalink)
Member: 573393
Thanks Meter: 11
roots Lenovo Moto M?
hi all
Please help for root leanove moto m?
thank,s
Old 04-05-2017, 22:55   #22 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,090
- Power on the phone
- Go to Settings - About phone - tap few times "build number" to open the settings for the developer
- Go to the developer settings - Enable "enable boot loader unlocking"
- Reboot in fastboot, via adb command "adb reboot bootloader",
or on the powered off phone, hold the volume up + power on, menu appears - select fastboot
- Adb command - in fastboot - "fastboot oem unlock", confirm with volume up button on phone
- Exit fastboot after done, by holding power on button for ~10 seconds
- We now have unlocked bootloader
- Download TWRP from - HERE and unpack in ADB folder on pc
- Reboot in fastboot - via adb command "adb reboot bootloader" or on the powered off phone, hold the volume up + Power on, hold until a menu appears.
- Select fastboot
- From adb, command : fastboot flash recovery TWRP_a1010.img
- From adb : fastboot reboot
- Hold volume up, untill menu appears, select recovery
- Now you are in TWRP, and can do "install ZIP", download Latest SuperSU and install.
- Root done.
b.r.
Alex
__________________
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 05-17-2017, 01:32   #23 (permalink)
Stunman112's Avatar
Member: 2567774
Thanks Meter: 254
PB2-670N any Root?
Looked all over and on .Ru sites and all supported roots are for 670M not 670N
Need Root for installing Gapps
Thanks
Old 05-23-2017, 18:51   #24 (permalink)
mediaextensions's Avatar
Member: 1123079
Sonork: 100.1586814
Thanks Meter: 434
- Select fastboot
- Root done.
b.r.
Alex
Alex,
I tried your method above to gain root but after install SuperSU via recovery phone restarts. I will be very grateful if u give me the stock recovery here.
E:\Lenovo>fastboot flash recovery TWRP_a1010.img
target reported max download size of 134217728 bytes
sending 'recovery' (13794 KB)...
OKAY [ 0.453s]
writing 'recovery'...
OKAY [ 0.716s]
finished. total time: 1.185s
Old 05-24-2017, 13:33   #25 (permalink)
Member: 1123079
Sonork: 100.1586814
Thanks Meter: 434
Originally Posted by mediaextensions View Post
Alex,
OKAY [ 0.453s]
OKAY [ 0.716s]
Thank Alex , I have solved my problem.
Old 06-10-2017, 10:00   #26 (permalink)
Member: 1965499
Thanks Meter: 2
lenovo a7700 root
lenovo a7700 imei invalid how to root
plz help for me
Old 07-07-2017, 21:04   #27 (permalink)
Member: 1687644
Thanks Meter: 3
K10a40 6.0 Do not root ????
Could you help me, grateful .....
Old 07-07-2017, 22:08   #28 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,090
Forget about root for that model.
b.r.
Alex
__________________
Old 07-30-2017, 05:46   #29 (permalink)
UTT
Member: 2662433
how to root LENOVO A7020A48 marsmellow 6.0
k5 note pls. help
The Following User Says Thank You to UTT For This Useful Post:
Old 08-12-2017, 19:21   #30 (permalink)
Crumarix1's Avatar
Member: 84300
Thanks Meter: 74
A1010a20, bootloader oem unlock not alowed...
after second try OK ! Unlocked .
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.20453 seconds with 8 queries
