Lenovo s90-a dead vibrate only need help I FLASH WRONG UNLOCKBOOTLOADER NOW DEAD VIBRATE ONLY NEED SOLUTION THIS I FLASH NOW DEAD NEED JTAG OR ANY SOLUTION LINK;;https://ainotech.com/how-to-flash-le...stom-firmware/ help |
open back door remove battery and re insert battery and correct file flashing qfil or other tool. |
1 Attachment(s) Okay ... so if you have under device manager, Qualcomm HS-USB Qdloader 9008 port, all is okay. You can flash using QFIL (Part of QPST suite) - download : QPST_2.7.438.3 Latest QFIL flashable rom - S90-A_S239_151126_ROW In case you have corrupted imei, use attached QCN file, first enable diag port, via keypad type : *#*#8899#*#* then restore via QFIL (Tools - QCN Backup/restore). b.r. Alex |
QCN File in attachments damaged when extract it !! |
I just re-downloaded, unpacked, all went normal. b.r. Alex |
1 Attachment(s) No still no archive found, Also I have tried with Winrar & Winzip and 7z same result.. This is another file.. It is now available in the attachments, TESTED. Regards, |
Hi, I solved the problem. How; Firstly disassembly lenovo s90. ( https://www.youtube.com/watch?v=8SW_DlAlwEk ) Remove the battery socket. Connect USB after power button 1 second. Computer see Qualcomm QDLoader HS-USB port ( 9008 ). copied |
