Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 09-02-2017, 02:33   #1 (permalink)
Member: 1057346
Sonork: 1606384
Thanks Meter: 10
Lenovo s90-a dead vibrate only need help
I FLASH WRONG UNLOCKBOOTLOADER NOW DEAD VIBRATE ONLY NEED SOLUTION
THIS I FLASH NOW DEAD NEED JTAG OR ANY SOLUTION LINK;;https://ainotech.com/how-to-flash-le...stom-firmware/ help
Old 09-02-2017, 03:44   #2 (permalink)
Member: 1210902
Thanks Meter: 81
open back door remove battery and re insert battery and correct file flashing qfil or other tool.
Old 09-02-2017, 22:02   #3 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,747
Okay ... so if you have under device manager,
Qualcomm HS-USB Qdloader 9008 port, all is okay.
You can flash using QFIL (Part of QPST suite) - download : QPST_2.7.438.3
Latest QFIL flashable rom - S90-A_S239_151126_ROW
In case you have corrupted imei, use attached QCN file,
first enable diag port, via keypad type : *#*#8899#*#*
then restore via QFIL (Tools - QCN Backup/restore).
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 5 Users Say Thank You to Brka For This Useful Post:
Old 09-04-2017, 12:38   #4 (permalink)
boganice's Avatar
Member: 5184
Thanks Meter: 154
QCN File in attachments damaged when extract it !!
Old 09-05-2017, 02:30   #5 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 6,747
Does it extracts normal, or unpacking error ?
I just re-downloaded, unpacked, all went normal.
b.r.
Alex
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 09-10-2017, 15:56   #6 (permalink)
boganice's Avatar
Member: 5184
Thanks Meter: 154
No still no archive found, Also I have tried with Winrar & Winzip and 7z same result..
This is another file.. It is now available in the attachments, TESTED.
Regards,
Old 11-24-2018, 05:48   #7 (permalink)
adnanali's Avatar
Member: 207308
Thanks Meter: 454
OK and worked brother check another pc
Old 11-19-2020, 21:24   #8 (permalink)
abcrino50's Avatar
Member: 68882
Sonork: 1577247
Thanks Meter: 105
Hi,
I solved the problem.
How;
Firstly disassembly lenovo s90. ( https://www.youtube.com/watch?v=8SW_DlAlwEk )
Remove the battery socket.
Connect USB after power button 1 second.
Computer see Qualcomm QDLoader HS-USB port ( 9008 ).
copied
The Following User Says Thank You to abcrino50 For This Useful Post:
Page generated in 0.29545 seconds with 8 queries
