Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 10-28-2016, 07:49   #16 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207(No More Use)
Thanks Meter: 706
Red face MT6582__Lenovo__Lenovo_TAB_2_A7-30HC__A7-30HC__4.4
Try This Version....
This file readed From Alive A7-30HC TAB...
Link
The Following 2 Users Say Thank You to tapas770 For This Useful Post:
Old 12-27-2016, 13:13   #17 (permalink)
campus's Avatar
Member: 568843
Thanks Meter: 47
Originally Posted by Prem_India View Post
working fine with this file thank you
The Following 3 Users Say Thank You to campus For This Useful Post:
Old 12-27-2016, 13:17   #18 (permalink)
campus's Avatar
Member: 568843
Thanks Meter: 47
A7-30HC_S0029_151021_ROW working fine boss
The Following 2 Users Say Thank You to campus For This Useful Post:
Old 01-09-2017, 13:09   #19 (permalink)
Member: 2670512
Lenovo A7-30HC Firmware
Download:
Hello Prem,
I am completely new to this. I have downloaded and extracted the files from you suggested. Can you post instructions on the process to follow? Many thanks.
The Following User Says Thank You to sh00nya For This Useful Post:
Old 03-06-2017, 06:43   #20 (permalink)
shishir1234's Avatar
Member: 2599736
Sonork: what is this?
Thanks Meter: 176
Thumbs up thanks prem india
thanks brother,many many thanks i already tired forthis tab firmware..but finally i am succed to flash your 1st firmware https://cloud.mail.ru/public/GxW8/5JNGZCS6G
The Following 4 Users Say Thank You to shishir1234 For This Useful Post:
Old 03-08-2017, 09:33   #21 (permalink)
Crazy Poster
Member: 2619617
Thanks Meter: 9
hi guys I have the same problem with Lenovo tab 2 A7-30HC . which had virus I did format with xxxxxx box, it gone Hang on logo. I flashed with SP flash tool it gone dead even do not boot . any one have solution please. ???????
The Following User Says Thank You to ilyaseen For This Useful Post:
Old 03-08-2017, 22:04   #22 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Check options in SPFT, use only SPFT from firmware package.
Maybe you didnt use correct Downlaod Agent (DA), some models require
secured loader (DA_SWSEC.bin etc.), also check if downloading
with checksum is enabled, in SPFT Options ...
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Old 03-22-2017, 13:07   #23 (permalink)
Member: 625339
Sonork: 100.1602858
Thanks Meter: 4
if not connect.. then .
vol + and vol - and power then insert cable...
my tab is alive with this Firmware........... (A7-30HC_S0029_151021)
The Following User Says Thank You to iqbalje For This Useful Post:
Old 04-17-2017, 20:00   #24 (permalink)
Member: 2118052
Thanks Meter: 567
I have.. lenovo2 a7-30hc
S000029 151010 prc
I flashed the same version but problem is there still remain..
When i insert or remove sim card .. the erroe popup.
Sim popup illegal, the mobile will shut down in 30 second
Pls chek out the sim card again and reboot.
I have done factory reset also.. but no luck..
Through revery olso.. but problem still remain..
... is there firmware problem??? Or ver problem..
The Following User Says Thank You to miftahulbari For This Useful Post:
Old 04-30-2017, 11:18   #25 (permalink)
Crazy Poster
Member: 2348009
Thanks Meter: 21
lenovo tab 2 a7-30hc dead after flash solved
1st firmware working fine
The Following User Says Thank You to mubashirali For This Useful Post:
Old 05-11-2017, 14:42   #26 (permalink)
Crazy Poster
Member: 2619617
Thanks Meter: 9
Hello Friends I tried to flash the given ROM but problem remained the same,, computer does not detect the Tab. What should be the solution???? Thanks in advance.
Old 05-11-2017, 22:08   #27 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,777
Standard procedure :
- Check Cable
- Check PC USB Port, try other
- Check drivers
- Check if something appears in device manager upon connecting
- Trying all the same on other pc/normal windows (Win7 etc.)
and if all fails,
- Disassembling and changing USB charging connector on device
b.r.
Alex.
__________________
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 05-16-2018, 14:19   #28 (permalink)
Member: 2652538
Tried both of the S0029 and S126 rom from PREM INDIA still doesn't able to resurrect my tablet
Yet to try the S000125, the problem first occured is my tablet started to reboot and stuck at logo so I flashed S0017 then it was dead so I kept on trying to flash many other roms it flashed successfully but the tablet is still dead =/
Old 06-08-2018, 15:33   #29 (permalink)
van
Member: 55247
Thanks Meter: 4
my a7 tab2 after flashing is dead...original firmware is this a7-30hc_s000021_150528_rom..pls share if u have...thanks in advance
Old 06-30-2018, 08:48   #30 (permalink)
tapas770's Avatar
Member: 2171294
Thanks Meter: 706
Arrow hello
Just try this version once..
MT6582__Lenovo__Lenovo_TAB_2_A7-30HC__A7-30HC__4.4.2__A7-30HC_S000029_151020_ROW
Download Link
Page generated in 0.23499 seconds with 8 queries
