Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 01-09-2018, 09:40   #1 (permalink)
Member: 535323
Thanks Meter: 3
Thumbs up Lenovo TAB 4 7" Essential TB4-7304F FRP Remove ?
hy can anybody help with frp lenovo tab7 essential ,i try a lot but no succes,android firmware 7.0!tks
The Following 2 Users Say Thank You to gicapxo For This Useful Post:
Old 01-22-2018, 17:02   #2 (permalink)
Member: 1089778
Thanks Meter: 11
+1 help brooo need remover frp pleasee
The Following User Says Thank You to IORYAGAMI For This Useful Post:
Old 01-23-2018, 00:40   #3 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,843
Okay,
BEFORE BEGIN - CHARGE FULLY your device/tab !!!
FOLLOW ALL STEPS CAREFULLY ! (Especially part with formatting) !!!
All mistakes are made by you, and you only ! No one will warrant anything !
All goes on your responsibility!
Now, lets make this guide as much simple as possible.
- Download ROM, with all needed inside: TB-7304F_S000060_171019_ROW - MIRROR
- Unpack archive. pass: lenovo-forums.ru
- Start SPFT, from unpacked folder \TB-7304F_S000060_171019_ROW\Flash-tool_for_WLAN_no_sim_device\flash_tool.exe
- Select DA Agent - DA_PL.bin
- Load scatter file from root folder \TB-7304F_S000060_171019_ROW\MT8167_Android_scatter.txt
- Main SPFT Window, go to drop-down menu "Options" - "Option" - "Download" - select both fields, close window
- Main SPFT Window - Go to "Format" tab, select "Validation", "Manual format flash",
copy/paste marked in red "Begin address" : 0x8000000 , "Format length" : 0x100000
- Press "Start" button, connect powered off device to cable.
- Wait for finish, green circle will be displayed (process goes fast - 4-7 seconds).
- Enter device recovery, make "Wipe data/Factory reset", then "Reboot device".
- FRP Should be gone.
If you encounter "DL Image Failed" or "Tool DL failed" in bottom left corner, and reboot,
Simply reflash device with provided rom.
(Same procedure, but you don't do any format, just from main window, Download button.)
p.s. Check attached images if something not clear. They explain all.
Now, try and post results.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Last edited by Brka; 09-23-2020 at 23:44. Reason: added spft pics / fixed da_agent info / fixed link
The Following 18 Users Say Thank You to Brka For This Useful Post:
Old 01-26-2018, 22:50   #4 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,843
Originally Posted by IORYAGAMI View Post
tnks tnks broooooo
solution : DA Agent (DA_PL.bin).
Okay, original post now edited with correct preloader info.
tnx for testing, have a nice day
b.r.
Alex
__________________
The Following 3 Users Say Thank You to Brka For This Useful Post:
Old 01-27-2018, 18:14   #5 (permalink)
jose miguel's Avatar
Member: 14862
Thanks Meter: 40
error frp
i test Select DA Agent ..
Old 01-28-2018, 00:44   #6 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,843
There is "authentication" file in same folder where SPFT is,
try to load it under third field (below scatter load field), name is "auth_sv5.auth" and retry operation.
If still the same, either you have different model, or you are doing something wrong.
b.r.
Alex
__________________
The Following 5 Users Say Thank You to Brka For This Useful Post:
Old 07-03-2018, 05:50   #7 (permalink)
Member: 792851
Thanks Meter: 139
Hi i m getting same problem and i have correct device how did u solve ur problem?
Old 07-03-2018, 13:53   #8 (permalink)
voltran2008's Avatar
Member: 861795
Thanks Meter: 1,276
Lenovo Tab 7 - TB-7304F Tested FRP Solution
This is for TB-7304F Model... Check your Model before this process.. Chipset MTK MT8167D
Download required tools and driver from here:
LENOVO TB-7304F FRP.zip
Extract zip "LENOVO TB-7304F FRP.zip"
Afterwards Extract Files in archive:
Install Drivers (Optional)
Open Flashtool:
Select "DA_PL.bin" (\Flash-tool\Flash-tool folder) in Download Agent
Select Scatter- loading file "MT8167_Android_scatter.txt" (\LENOVO TB-7304F FRP folder)
Afterwards Tick Format Tab at top... Select Manual Format Flash... Do not touch Region... Enter these:
Begin Adress[HEX]: 0x8000000
Format Length[HEX]: 0x100000
Click Start button... Power OFF device and connect with holding volume down...
Congratulations FRP is off... Reboot device and you will be able to bypass Wi-Fi (Google Account)
The Following 12 Users Say Thank You to voltran2008 For This Useful Post:
Old 07-26-2018, 06:27   #9 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 210
lenovo tab 7304f dead after format need working file to revive
after that flashing erro anyone help me please
The Following User Says Thank You to Techsky For This Useful Post:
Old 07-26-2018, 14:29   #10 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,843
Post #3 and #9. Read carefully, download needed files and fix it.
B.r.
Alex
__________________
Old 07-26-2018, 14:55   #11 (permalink)
Member: 2252481
Sonork: 1660352
Thanks Meter: 210
B.r.
Alex
bro where am i getting wrong seems everything looks ok loading files ok DA ok what is the problem my cpu mt 8167A help me please to revive it
Old 07-26-2018, 18:07   #12 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,843
First and main problem is when you did FULL FORMAT of the device,
no idea where you got that (bad/stupid) idea.
With that move, you lost all calibrations, imei/wifi/bt/serial no.
Now, regarding this state of device ...
Try changing DA Agent into DA_SWSEC or DA_SWSEC_CRYPTO20 and try to flash preloader only.
Try all possible combinations of DA Agents, also try with or without holding volume buttons
when inserting usb cable into powered off device.
b.r.
Alex
__________________
Old 07-27-2018, 20:09   #13 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,843
Some more info ...
TB-7304X - LTE , MT6737M
TB-7304i - 3G , MT8735D (which is basically same as MT6737M)
TB-7304F - Wi-Fi , MT8167
I read on other forums that someone with same problem,
solved it with using DA_SWSEC.bin and normal scatter + FIRMWARE UPGRADE option.
I suggest you to try the same.
I re-packed / re-uploaded SPFlashTools for TB-7304 series.
Download : SPFlashTool_Lenovo_TB-7304i-x-f
p.s. Try without auth file, with different model flasher, DA_PL, DA_SWSEC, something must work.
also, timing may be the problem - try holding power button and when device reboot, instantly press DOWNLOAD button, etc.
b.r.
Alex
__________________
The Following 7 Users Say Thank You to Brka For This Useful Post:
Old 12-10-2018, 22:37   #14 (permalink)
Member: 288521
Thanks Meter: 685
perfect instructions- working great.
Old 05-03-2019, 04:20   #15 (permalink)
Member: 2906417
Hi all, I have a TB-7304i- 3G , MT8735D, and would like to flash the ROM. The device does not have USB debugging under Developer Options.
Thanks to the SPFT posted by Brka, atlease now I can load scatter file. Prior to this, all SPFT I've downloaded will post C++ Runtime Error.
The scatter file posted in this thread is for MT8167, does it work with MT8735D? First time using SPFT and MTK chip.
Thanks
Page generated in 0.23627 seconds with 9 queries
