Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 09-04-2018, 09:05   #1 (permalink)
Member: 2850359
[Request] Lenovo Yoga 3 Pro Rom (YT3-X90Y)
Hello!!
I am looking some rom for this tablet. Can somebody help me?
Thanks
Old 09-04-2018, 19:55   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,826
Exact X90Y files I couldn't find, but it should be possible (like another Chinese model),
to "convert" to ROW model.
Your model is WiFi-only (no LTE module), so correct ROM should be same as for X90F
Models comparision (ROW)
Lenovo YT3X90F WLAN
Lenovo YT3X90L LTE
Lenovo YT3X90X LTE
Available ROM's:
Model "YT3-X90F Refresh" - with 4Gb RAM / 64Gb ROM
YT3-X90F_ENG_S200013_1609061604_WW17_BP_ROW
YT3-X90F_USR_S200013_1609061604_WW17_BP_ROW
You will need both files, if you have this (4/64) model,
needs to be flashed with ENG then USR file.
Flashing method :
- Put phone to DNX mode (volume up + volume down + power button)
- DNX mode should be displayed on screen
- Download, install and start PlatformFlashTool_5.5.1.0
- From PFT, from ENG ROM folder, load flash.json, configuration should be empty
- Press START, wait until finished, if tablet don't auto restart, reboot it by holding power button longer
- Power it off, hold Volume up + power on, until FASTBOOT displayed on screen
- In PFT flasher, from USR ROM folder, load flash_factory_1st_stage.json, under configuration should be (or select manually) - factory1st
- Press START and wait for finish, it should reboot and you are done.
test and post results
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following 2 Users Say Thank You to Brka For This Useful Post:
Old 09-10-2018, 12:24   #3 (permalink)
Member: 2850359
Thank you, I will try your manual!!!
Thanks!!!!
Old 09-10-2018, 12:36   #4 (permalink)
Member: 2850359
It works!!!! Thanks!!!
Old 09-10-2018, 22:09   #5 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,826
So - did you follow procedure, can you a bit describe exactly what you did ?
it may be helpful for other people ...
tnx in advance
__________________
The Following User Says Thank You to Brka For This Useful Post:
Old 09-11-2018, 08:47   #6 (permalink)
Member: 2850359
I follow you procedure and It works at first time. It is easy and I am not find some problem
Thank.
The Following User Says Thank You to pruebasmaslenov For This Useful Post:
Page generated in 0.14188 seconds with 8 queries
