A9 s-off and unlock problem Code: Reading information... Code: Sending oem writesecureflag 0 |
Hello, Please PM your clip ID, I will help. |
I have sent PM. Please verify. |
same issue, Can't simunlock. Using Direct mode is successful for s-off and cid write, but fail on unlock. Sending oem clearsimlocktype ... (bootloader) [ERR] Command error !!! OKAY Execution time is 0(ms) Operation finished Phone DISconnected Unlocking via ftm mode also just gives error. |
Sorry, but you have to read first. First you have to read this post again, and then you have to read the name of the button you are trying to press. Don't you think that "DESIRE SERIES ONLY" is written there for a reason? So if you have a problem - be so kind to include at least your model name/ID, instead of useless "same problem", otherwise noone will be able to help you. |
have same error sent you on Skype :) |
hey guys, i also want to s-off and unlock a HTC ONE A9 AT&T phone but i cannot get into FTM mode, either with pressing buttons or with the XTC Tool. It just reboots the phone normaly. Can you guys help me :) |
Phone in download mode says SD NOT MOUNTED but i connected the xtc clip like 1000 times and the cable is also ok (no cuts or what so ever), when i press the Direct s-off I get of course the Error: Sending oem writesecureflag 0 ... FAILPERMISSION DENY (NOT_FIND_SMART_IO) FAILED (remote: PERMISSION DENY (NOT_FIND_SMART_IO)) Execution time is 16(ms) Operation finished |
http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ |
Thx for replying. I`ve already did this in first place as Im not new to unlocking or repairing of Smartphones :) but XTC is sometimes really a pita... |
Hahaha, sounds dirty. But even if i press it as hard as i can, and it is fitted, its not reading the sd...i will try again and report. Thank you! |
The sd tray is really bad on these phones, I get connection after many tries, but it works, also just want to confirm that A9 sprint conversion works. |
