(bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] Ja (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] Javacard reset response timeout C= 1000. OKAY i am having this error phone is htc 626 , and i cant change cid , or s-off or anything elese , i try in direct mode , and direct mode with adapter , i try offline too , but doesnt change anything , i cant remove frp , i cant enter phone to activate developer mode . |
Hello, This error means that your smartcard is not inserted, or inserted incorrectly. Alternatively you can eject the smartcard, gently clean it with rubber or cloth and insert back. |
I try to get out card to clean , but doesnt work , i try with power adapter and is same story , in sd card the phone read files , but doesnt change anything . Do u have something to check the smart card if is ok . Its not working neither with power adapter , or java card . phone is htc 626ph |
You can try to do filesytem repair of your clip, in case the problem is in filesystem: http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ The smartcard itself (separated) can't be checked, but you can also run XTC 2 Client 1.4 as an alternate test. Smartcard must be inside of XTC 2 Clip in this scenario. |
Ok i run smartclip xtc 2 client , and it reads the serial nr . but doesnt comunicate with phone , do u have any ideea about this problem . I do file system repayr about 10 times . and same problem . Realy duno where to start with this issue . |
Now i remove frp , and i unlocked booloader , but same error when i try co change cid or soff [JAVACARD_ERR] Javacard reset response timeout C= 1000. OKAY with offline sdcard , it reads all files , and it gives me press volume up to restart , but nothing change . |
When i try to do sd change i get in red Check keycard failed Can u help me with that . Thanks . |
Sent u pm 2 days ago ... |
Hello, See my reply in PM please, but it looks like the smartcard is damaged. However, please follow my instructions from PM to see if it helps. |
