Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 01-11-2017, 06:49   #46 (permalink)
Member: 721542
Thanks Meter: 56
Originally Posted by yurais View Post
The are different versions of 530
This one is from metropcs.
Enviado desde mi SM-N920T mediante Tapatalk
i had 5 pcs the same model 530. i just tested one and posted successful report, but now all the others can not be unlocked now.
Old 01-11-2017, 10:48   #47 (permalink)
Member: 2416253
Thanks Meter: 4,162
bootloader unlock is not enabled.
and to enable it phone must be s-off
It cant be soff since it ignores the clip connected in the sd slot.
so, what is next?
2 weeks now here with this phone without doing anything
Starting bootloader unlock procedure
Phone detected, reading token...
Please wait, your phone will now be rebooted to bootloader...
Checking server connection...
Phone DISconnected
Communicating with the XTC 2 Clip ...
Phone connected [FA6AXBR01351] *** Fastboot mode
Phone is in bootloader mode
Error: Unable to detect data location!
To enable bootloader unlock, you should boot to Android, go to developer settings and enable it, S-OFF is not required in this case.
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 01-11-2017, 10:49   #48 (permalink)
Member: 2416253
Thanks Meter: 4,162
oem get_identifier_token
*** Command started ***
... FAILunknown command
FAILED (remote: unknown command)
Execution time is 12(ms)
*** Command finished ***
It must be done in download mode, not in bootloader.
Old 01-11-2017, 16:30   #49 (permalink)
Member: 220595
Thanks Meter: 355
this instructions were not written elsewhere, thank to this tip now bootloader is unlocked.
So, now what? how do I unlock the phone? I will try to s-off now.
Old 01-11-2017, 18:23   #50 (permalink)
Crazy Poster
Member: 2280189
Thanks Meter: 10
Please wait, preparing your phone...
Sorry, adb server is out of date. killing...
* daemon started successfully *
htc_a16
is not yet supported.
Old 01-11-2017, 18:36   #51 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,190
htc_a16
Kill external adb server or just reboot PC.
Old 01-11-2017, 18:37   #52 (permalink)
Member: 220595
Thanks Meter: 355
Hello
After bootloader unlock, I have tried to unlock using the usual SD method with the desire 530 files copied to the clip
This time the phone is not ignoring the clip but am getting the error on the image
Old 01-11-2017, 19:35   #53 (permalink)
Member: 220595
Thanks Meter: 355
Finally worked out to unlock the beast... desire 530 metropcs
Finally I managed to unlock the phone.
there is lack of support here !!! one has to find the answers oalmost on their own...
To unlock phone you * MUST *
1. enable OEM Unlock on developer options
2. Unlock BootLoader
3. s-OFF
4. Copy the required desire 530 files using SD Editor TAB
5. Insert Clip as SD in phone and use FTM Button
only after all of this phone will be unlocked, there is no other way for now !!
Bootloader unlock process (only works after :Enable Oem Unlock)
Token detected successfully
Connecting to the server...
Waiting for the server to process request, it may take up to 5 minutes...
Your request was processed successfully! Unlock token has been obtained
Sending flash unlocktoken "C:\Program Files (x86)\XTC 2 Tool\\unlocktoken_FA6AXBR01351.bin"
sending 'unlocktoken' (0 KB)... OKAY
writing 'unlocktoken'... (bootloader) flash unlocktoken
(bootloader) [KillSwitch] : /dev/block/bootdevice/by-name/frp
(bootloader) [KillSwitch] Last Byte is 0X01, enable unlock
(bootloader) unlock token check successfully
OKAY
Execution time is 1(s)
Please continue the unlock process on your phone.
S-off process ok
HTC Desire 530 detected
Android release: 6.0.1
Please wait, processing your request...
Finished. Your phone will be S-OFF on restart.
Phone DISconnected
Old 01-11-2017, 19:40   #54 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,190
Problem solved. Delete please.
Old 01-11-2017, 19:44   #55 (permalink)
Member: 220595
Thanks Meter: 355
Originally Posted by Dr_Wolodya View Post
You need to flash TWRP and start S-OFF operation from recovery.
Hello
problem solved, read above post
Old 01-12-2017, 00:49   #56 (permalink)
Crazy Poster
Member: 2280189
Thanks Meter: 10
I have this error
Help me please!!
Old 01-12-2017, 00:52   #57 (permalink)
Crazy Poster
Member: 2280189
Thanks Meter: 10
Old 01-12-2017, 01:06   #58 (permalink)
Member: 220595
Thanks Meter: 355
I have this error
Help me please!!
be sure you copied the desire 530 required files using the SD Editor Tab.
insert the clip in the phone and put phone in bootloader or download mode
while phone connected to USB press the FTM button on xtc software.
Old 01-12-2017, 03:10   #59 (permalink)
Crazy Poster
Member: 2280189
Thanks Meter: 10
special unlock/IMEI Tab right because in the sd mode editor Tap only shows that i have to put the imei and secury s-off and more i dont know what im doing wrong.. thank for you advise
The Following User Says Thank You to Leo_systems For This Useful Post:
Old 01-12-2017, 03:23   #60 (permalink)
Member: 220595
Thanks Meter: 355
Yes, my mistake, special unlock, that's the tab, sorry
Page generated in 0.21009 seconds with 9 queries
