08-17-2015, 21:52 | #31 (permalink) |
No Life Poster Join Date: Aug 2005 Location: MOON Age: 43
Member: 174173 Status: Offline Thanks Meter: 115 | Trying to connect in modem mode... Reading security info... Security is ON Reading CID... Reading IMEI... Reading SIMLOCK info... Checking lock status: Phone is UNLOCKED SUCCESSFULLY connected XTC2CLIP connect in Phone Problem S-Off Trying to perform S-OFF... Error: The phone has returned an error, command failed. Do you have smartcard inserted into the phone? You may need to S-OFF first also. Imei Trying to repair IMEI... Error: The phone has returned an error, command failed. Do you have smartcard inserted into the phone? You may need to S-OFF first also. Unlock Sim not Problem Trying to perform sim unlock for network lock... SUCCESS: The command was executed! Trying to perform sim unlock for network subset... SUCCESS: The command was executed! Trying to perform sim unlock for service provider lock... SUCCESS: The command was executed! Trying to perform sim unlock for corporate lock... SUCCESS: The command was executed! Trying to perform sim unlock for sim lock... SUCCESS: The command was executed! |
08-19-2015, 17:49 | #35 (permalink) |
Member: 174173 Status: Offline Thanks Meter: 115 | Solved my Problem 1. Direct (option) sdcard xtclip insert in phone Write security 0 - Security off (S-OFF) 2. Legacy (option) Step 2:Switch to modem mode Step 3:Connect 3. Write Imei Logs Operations S-OFF Phone connected [SH1CYVN02539] Sending oem writesecureflag 0 (bootloader) £…£÷HTCE (bootloader) Done! (bootloader) sdc_ns_reg value=0xFF9E0B58 (bootloader) sdc_ns_reg value=0xFF9E0B58 (bootloader) sdcc_init_memory_device done (bootloader) sdc_ns_reg value=0xFFFE0B40 (bootloader) Wait for AMSS ready Sending oem writesecureflag 0 (bootloader) writesecureflag: keycard remain count 10000 (bootloader) writesecureflag: set security flag off successfully (bootloader) AMSS is ready (bootloader) writesecureflag: keycard remain count 10000 (bootloader) writesecureflag: set security flag off successfully Write Imei Sending oem writeimei 35456xxxxxxxxx |
09-02-2015, 11:30 | #40 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | |
10-28-2015, 23:33 | #43 (permalink) |
Junior Member Join Date: May 2014
Member: 2185617 Status: Offline Sonork: adyredro Thanks Meter: 0 | Hi! I have the same problem with one Htc Buzz when i try to unlock. In Legacy mode, i put the sim card from clip in the phone. Only in HBOOT can see the phone in COM3 and can chose conect/disconect. When switch to FASTBOOT and chose Read phone info i recieve: Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 1.01.0002 (bootloader) version-baseband: 3.35.20.10 (bootloader) version-cpld: None (bootloader) version-microp: 0622 (bootloader) version-main: 2.24.164.1 (bootloader) serialno: HT0CCPY05590 (bootloader) imei: 3557970XXXXXXXX (bootloader) product: buzz (bootloader) platform: HBOOT-7225 (bootloader) modelid: PC4910000 (bootloader) cidnum: VODAP304 (bootloader) battery-status: good (bootloader) battery-voltage: 4192mV (bootloader) partition-layout: HTC (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-ab9ba933 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 Execution time is 31(ms) all: Done! Reading secure flag information ... (bootloader) [ERR] Command error !!! Execution time is 31(ms) OKAY Reading CID information ... (bootloader) [ERR] Command error !!! Execution time is 15(ms) OKAY Reading MEID information ... (bootloader) [ERR] Command error !! In FASTBOOT mode when chose "Switch to modem mode" i recieve: Trying to swtich into modem mode ... Sending oem rtask c ... and FASTBOOT menu from phone is frieze. What i have to do? Thanks! |
10-29-2015, 09:41 | #44 (permalink) | |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
The COM port you see in fastboot mode cannot be used, it's an old serial "mirror" to the USB fastboot commands. | |
10-30-2015, 22:53 | #45 (permalink) |
Member: 2185617 Status: Offline Sonork: adyredro Thanks Meter: 0 | If i have new COM port i will install, but my computer don't recognize new COM. In device manager all drivers is intaled. Meybe i don't have the right drivers instaled. Can u help me on team viewer? Thanks! |
