Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 06-30-2015, 20:27   #1 (permalink)
onaikel's Avatar
Member: 1361178
Thanks Meter: 95
xtc2clip no work [solved]
direct mode:
Sending oem writesecureflag 0
... (bootloader) [JAVACARD_ERR] SD/USBDISK Init error
(bootloader) writesecureflag: Permission denied, value 1
Execution time is 281(ms)
OKAY
Operation finished
offline mode:
Old 06-30-2015, 22:23   #2 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
How to Remove Tampered Banner on HTC One M8
Old 06-30-2015, 22:39   #3 (permalink)
Member: 2416253
Thanks Meter: 4,162
Originally Posted by onaikel View Post
direct mode:
OKAY
Operation finished
offline mode:
You must connect clip before powering phone on. Otherwise you have to press 'reboot bootloader' prior to using direct mode.
The Following 2 Users Say Thank You to xtc2clip For This Useful Post:
Old 07-01-2015, 00:18   #4 (permalink)
onaikel's Avatar
Member: 1361178
Thanks Meter: 95
power off, power on, reboot bootloader nothing works, maybe box is damage??
Old 07-01-2015, 08:50   #5 (permalink)
Member: 1222089
Sonork: 100.1583019
Thanks Meter: 2,688
Activate your clip ., if you not activate already
Try also offline method
http://forum.gsmhosting.com/vbb/f961...steps-1964502/
Old 07-01-2015, 09:16   #6 (permalink)
Member: 2335578
Thanks Meter: 105
Sending oem readsecureflag
... (bootloader) read secure flag: 3
cause my phone was s-off before I put hook to box now it won't s-off or flash ruu or download mode
will not change to s-off
Old 07-01-2015, 10:32   #7 (permalink)
Member: 2416253
Thanks Meter: 4,162
1. Connect your clip to PC to make sure it's detected, read files using XTC2Tool - does it read files OK?
2. The good idea is:
a) power off phone
b) connect clip to phone
c) power on phone in bootloader mode
d) goto fastboot mode using phone menu
e) Use XTC2Tool in direct mode and use "Write security flag" and set it to 0.
f) Post result here.
Old 07-01-2015, 10:47   #8 (permalink)
Member: 2416253
Thanks Meter: 4,162
Please explain your problem in details.
1. You cannot turn phone to S-ON just by "hooking the box"
2. Some commands and one some phones like writecid will turn S-ON, you simply need to do S-OFF after this.
3. Please post your model and the way you are trying to S-OFF, your logs only shows that you are reading the security flag.
And next time please be so kind to create a separate thread for your problem to help us to support you better.
Old 07-01-2015, 11:08   #9 (permalink)
Member: 2416253
Thanks Meter: 4,162
You can flash it to original firmware and it will remove the tamper flag.
However, we will consider adding this feature to the nearest updates.
The flag itself doesn't affect the way your phone works, and if you are intended to take it to your service center, you should know that they will detect modified firmware even without the tamper flag and may refuse to service it.
So if you need to pass it to service center, it's always good to reflash with original firmware.
Old 07-01-2015, 15:27   #10 (permalink)
onaikel's Avatar
Member: 1361178
Thanks Meter: 95
is activated!! tried in many htc m8, m7, htc one max sprint and same result
Old 07-01-2015, 15:31   #11 (permalink)
onaikel's Avatar
Member: 1361178
Thanks Meter: 95
a) power off phone
tried all options i have java card and work perfect but this box no work i dont know what is wrong, you have how to check box???
Old 07-01-2015, 15:50   #12 (permalink)
Member: 2416253
Thanks Meter: 4,162
I asked you to post log, but you didn't. I cannot help if you provide us only with "tried all options it didn't work".
You may try to reset your clip using this procedure:
http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/
Old 07-01-2015, 15:58   #13 (permalink)
onaikel's Avatar
Member: 1361178
Thanks Meter: 95
ad what is this in first post???
direct mode:
OKAY
Operation finished
i know how to use because i have java card, same card reader java card work xtc2clip not, try to repair the filesystem and will post the results
thanks
Old 07-01-2015, 16:07   #14 (permalink)
Member: 2416253
Thanks Meter: 4,162
direct mode:
OKAY
Operation finished
thanks
If you did everything right, and connected clip before power on, and got this message - SD/USBDISK Init error, then there is only one case - your flex is damaged.
And what do you mean by "same reader java card work" - are you saying that your clip is not detected on computer?
Old 07-01-2015, 17:13   #15 (permalink)
onaikel's Avatar
Member: 1361178
Thanks Meter: 95
... (bootloader) vreg_set: request is duplicated id 14
(bootloader) ruby_init_sd, SD card power on ok
(bootloader) [SD_HW_ERR] SD: No device attached
(bootloader) [JAVACARD_ERR] SD Init error
Execution time is 2250(ms)
OKAY
Operation finished
Phone connected !
flex changed, filesystem repaired now what?
Page generated in 0.26089 seconds with 9 queries
