07-19-2017, 09:03 | #1 (permalink) |
Insane Poster Join Date: Jul 2013 Location: england
Member: 1988221 Status: Offline Sonork: slam4neon Thanks Meter: 22 | need htc a9 ruu exe Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_hiaeuhl (bootloader) version: 1.0 (bootloader) max-download-size: 751200000 (bootloader) serialno: HT5C7BE04771 (bootloader) slot-count: 0 (bootloader) current-slot: (bootloader) imei: 352636073250982 (bootloader) version-main: 2.16.161.5 (bootloader) boot-mode: download (bootloader) version-baseband: 1.1.U40062.1@61209 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PQ910000 (bootloader) cid: VODAP001 all: Execution time is 1(s) Reading CID information ... (bootloader) cid: VODAP001 OKAY Execution time is 61(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 6(ms) Reading IMEI1 information ... (bootloader) imei: 352636073250982 OKAY Execution time is 9(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 8(ms) Reading secure flag information ... (bootloader) Device security level S-ON OKAY Execution time is 8(ms) Reading serial number information ... (bootloader) Device Serial No. is HT5C7BE04771 OKAY Execution time is 4(ms) Read information completed. |
07-20-2017, 10:00 | #3 (permalink) |
Member: 1988221 Status: Offline Sonork: slam4neon Thanks Meter: 22 | yes plz its vodafone. from XTC2.net Support . i tried all but not successful . i saw this ruu file on easy firmware web ......plz can you help me ... my client mobile is formatted . does not have os system in mobile |
07-20-2017, 12:49 | #4 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
1.62.161.2 is pre 2.16.161.5. Let me know if it helps. | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
07-20-2017, 12:59 | #5 (permalink) | |
Junior Member Join Date: Mar 2016
Member: 2545921 Status: Offline Thanks Meter: 7 | Quote:
You are current S-On, you will need to S-Off first to flash the older FW 1.62.161.2 as your version is 1.62.161.5. Br | |
07-20-2017, 17:00 | #6 (permalink) | |
Member: 1988221 Status: Offline Sonork: slam4neon Thanks Meter: 22 | more help plz Quote:
Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_hiaeuhl (bootloader) version: 1.0 (bootloader) max-download-size: 751200000 (bootloader) serialno: HT5C7BE04771 (bootloader) slot-count: 0 (bootloader) current-slot: (bootloader) imei: 352636073261997 (bootloader) version-main: 2.16.161.5 (bootloader) boot-mode: download (bootloader) version-baseband: 1.1.U40062.1@61209 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PQ910000 (bootloader) cid: VODAP001 all: Execution time is 6(ms) Reading CID information ... (bootloader) cid: VODAP001 OKAY Execution time is 54(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 7(ms) Reading IMEI1 information ... (bootloader) imei: 35263607 OKAY Execution time is 5(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 5(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 7(ms) Reading serial number information ... (bootloader) Device Serial No. is HT5C7BE04771 OKAY Execution time is 4(ms) Read information completed. now cant flash ...just flash one zip file ended with error | |
07-20-2017, 17:03 | #7 (permalink) | |
Member: 1988221 Status: Offline Sonork: slam4neon Thanks Meter: 22 | Quote:
Starting flash process... target rom version: 1.62.161.2 found large-zip header, file count: 23 processing file 1/23... sending 'zip' (113705 KB)... OKAY [ 5.289s] writing 'zip'... (bootloader) HOSD CL#853511 (bootloader) ERR check AES encrypted magic string failed. (bootloader) end@Done FAILED (remote: 12 RU_ZIP_ERROR ) finished. total time: 7.322s Flash process completed. Flash not successfull, reboot will not be done 12 RU_ZIP_ERROR en red worlds | |
06-25-2020, 13:05 | #9 (permalink) |
Freak Poster Join Date: Jun 2012
Member: 1776947 Status: Offline Sonork: 100.1659966:tjjxxs Thanks Meter: 74 | kernel: lk product: htc_hiaeuhl version: 1.0 max-download-size: 751200000 serialno: HT5AMBE07887 slot-count: 0 current-slot: imei: 352636070789222 version-main: 2.16.161.5 boot-mode: download version-baseband: 1.1.U40062.1@61209 version-bootloader: 1.0.0.0000 mid: 2PQ910000 cid: VODAP001 |
