Htc A50cmg_dwg Imei Issue I have an htc d728h came as network problem it show imei when i try *#06# but it not show the same imei when show barecode from fastboot mode Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_a50cmg_dwg (bootloader) version: 1.0 (bootloader) imei: 000000000000000 (bootloader) version-main: 1.09.401.1 (bootloader) boot-mode: download (bootloader) version-baseband: READ version-baseband ERROR (bootloader) version-bootloader: 1.01.0000 (bootloader) mid: 2PQ830000 (bootloader) cid: all: Execution time is 5(ms) Reading CID information ... (bootloader) cid: OKAY Execution time is 31(ms) Reading MEID information ... FAILREAD MEID ERROR FAILED (remote: READ MEID ERROR) Execution time is 2(ms) Reading IMEI1 information ... (bootloader) imei: 000000000000000 OKAY Execution time is 0(ms) Reading IMEI2 information ... FAILREAD IMEI2 ERROR FAILED (remote: READ IMEI2 ERROR) Execution time is 0(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 0(ms) Reading serial number information ... (bootloader) Device Serial No. is OKAY Execution time is 0(ms) Read information completed. how can i write the imei |
use special unlock tab for this model |
i tried that method it show stage 1 to stage 4 done found new imei 35........... found new imei 2 35........ rebuild imei process 5 done with 2 error contact support with error 00000004 |
RESPONSE*FROM*IO € n‰™ia_r=#d /T„ ج fH†!t8D2{r8+ ϲfa‡QŠ03N/oO^, UŽ–•›u†b Œ+bJ U œ~1 8oB^™%9jŠL aœ@S–k˜hJ— `z¨l…SCzŸY3#Q>S*T—zC<H:պ’ ‰J1J$B2aM=†š˲>€Œ>„Š.…O,Pg 4S *ŠPlease wait... Stage 3 done. Process done 3 steps with 0 errors Rebooting in 5 seconds ... Rebooting in 4 seconds ... Rebooting in 3 seconds ... Rebooting in 2 seconds ... Rebooting in 1 seconds ... =============================RESPONSE*FROM*IO € ‰™/medc€+Q•y˜=;ằUT”<GȤO}“g?ŸKWA@*Q_ cM+d5[ļ|2f*w ttMYPŽF:HQX|lH]”•MM‘g‡—†&6ϩ…9I‘†zZ†2o„& EƒHRi!“i ޏ}k8€‰SkL’f1ŠPztu™†ofH J%/’ f1\to“<œ—N$@Please wait... Stage 4 done. Process done 5 steps with 2 errors Code for support: 00000004 Rebooting in 5 seconds ... Rebooting in 4 seconds ... Rebooting in 3 seconds ... Rebooting in 2 seconds ... Rebooting in 1 seconds ... ==RESPONSE*FROM*IO € ‰™/med†* #AId؍[c•…€!2ž$’—8$wǻgxBPŽm*0v>— {-[&ƒ3D>xHê,crî™|y#a*oX'=wŸP› @4›vy Ž‡hϤλ‚~xm2gšw%\‹_Z–fL •s}z –qʦ‹sT)€ա=<MŠŠv og||".^Ϳ~ ž/`™* 2'6L^hˆ™z…RC—q`Please wait... Stage 4 done. Found IMEI file, setting new IMEI to: 356258956947141 Found IMEI2 file, setting new IMEI2 to: 356258956947158 Rebuilding IMEI Process done 5 steps with 2 errors Code for sRESPONSE*FROM*IO € ‰™/med€:%O˜†-eX‘,?~‰]1IG˜q_*žŠ‘…qIqŸr#D ,H !m‡ Ţ/a#YCTˆ3Œ?‡|TL) ˜'ˆ* 9?PGr”ټܲ’$U—D7*7,خœ"_eں“U'94. ‚“]"$aŸI [icJ‹;>tŠx/S_P9D$Ž†‰ƒY“2 2'6L^hˆ™z…RC—q`(7:&DV˜`‰rcr@Q"%40N\ jxŠ›‡sb•PA5*$8FTbšp‹„•“ ,¥>@R+:dN_vm|‰” …›*$ÿ6H ;Z*^lO}~l ƒ†‘—.<B)8P fo~tL]‹™–‡Please wait...RESPONSE*FROM*IO € ƒ ] =============================== XTC 2 Clip - service tool v2.33 Detected release: A50CMG_DWG_L51_DESIRE_SENSE70 Detected model: D728G DUAL SIM [MTK] PreRESPONSE*FROM*IO € ‰™/med ŠžeHP xC_š`!bN~=IYHvYœ|s#I…3 ']rFK:@€G4r ~>YDSO’Fe?n\“ˆˆH †› l^"u>M Please wait... Stage 4 done. Found IMEI file, setting new IMEI to: RESPONSE*FROM*I Found IMEI2 file, setting new IMEI2 to: RESPONSE*FROM*I Rebuilding IMEI Process done 5 steps with 2 errors Code for support: 00000004 Rebooting in 5 seconds ... Rebooting in 4 seconds ... Rebooting in 3 seconds ... Rebooting in 2 seconds ... Rebooting in 1 seconds ... this log from xtc 2 clip |
Same Error Sir RESPONSE*FROM*IO € ‰™/medx)–]iD8p‘OTH}٩Ž/‚}6X›4XVkp.U†|:u€ kW K—*rX7˜kV„Ĩ߾sbm1W†< pSIŒ7”e>L*:‰|+“]a#IœY0FI:f—[ž†’'C`cSEˆ^‹5|=>5xš6ov RŒŸHgts*Npqh 2'6L^hˆ™z…RC—q`(Please wait... Stage 4 done. Found IMEI file, setting new IMEI to: 356258956947141 Found IMEI2 file, setting new IMEI2 to: 356258956947158 Rebuilding IMEI Process done 5 steps with 2 errors Code for support: 00000004 Rebooting in 5 seconds ... Rebooting in 4 seconds ... Rebooting in 3 seconds ... Rebooting in 2 seconds ... Rebooting in 1 seconds ... |
change flex and try again |
I tried to change the flex from xtc clip and still same error |
make sure files were correctly copied from special tab selecting correct model |
