09-10-2018, 12:08 | #1 (permalink) |
Registered User Join Date: Sep 2005 Location: Abuja nigeria
Member: 185010 Status: Offline Sonork: alias-albertino Thanks Meter: 170 | htc m10 reboot on htc logo cant s-off not work i need file that can flash this phone please here is the infor--- Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_pmeuhl (bootloader) version: 1.0 (bootloader) max-download-size: 1579200000 (bootloader) serialno: HT676BN00159 (bootloader) current-slot: (bootloader) imei: 354261071327308 (bootloader) version-main: 2.41.401.3 (bootloader) boot-mode: download (bootloader) version-baseband: 1.0.U010241a@61226 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PS620000 (bootloader) cid: HTC__J15 all: Execution time is 4(ms) Reading CID information ... (bootloader) cid: HTC__J15 OKAY Execution time is 189(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 4(ms) Reading IMEI1 information ... (bootloader) imei: 35426107132xxxx OKAY Execution time is 7(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 8(ms) Reading secure flag information ... (bootloader) Device security level S-ON OKAY Execution time is 11(ms) Reading serial number information ... (bootloader) Device Serial No. is HT676BN00159 OKAY Execution time is 27(ms) Read information completed. Your clip can be safely removed now Phone DISconnected |
09-10-2018, 14:39 | #4 (permalink) | |
Member: 185010 Status: Offline Sonork: alias-albertino Thanks Meter: 170 | Quote:
target rom version: 2.41.401.3 found large-zip header, file count: 25 processing file 1/25... sending 'zip' (108168 KB)... OKAY [ 4.534s] writing 'zip'... (bootloader) HOSD CL#857212 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) Perform pre-update (bootloader) WARN Skip partition_info due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 34 images from zip(zip_type=3) (bootloader) start@34 (bootloader) apppreload.img@BYPASS (bootloader) aboot_signed.img@100% (bootloader) cota.img@BYPASS (bootloader) xbl-8996-1.img@100% (bootloader) hosd_signed.img@100% (bootloader) apdp-8996-1.img@BYPASS (bootloader) rpm-8996-1.img@100% (bootloader) pmic-8996-1.img@100% (bootloader) boot_signed.img@BYPASS (bootloader) recovery_signed.img@BYPASS (bootloader) slpi.img@BYPASS (bootloader) adsp.img@BYPASS (bootloader) dsp.img@BYPASS (bootloader) rcdata.img@BYPASS (bootloader) rfg_3.img@BYPASS (bootloader) venus.img@BYPASS (bootloader) modemst1.img@BYPASS (bootloader) modemst2.img@BYPASS (bootloader) fsc.img@BYPASS (bootloader) tz-8996-1.img@100% (bootloader) hyp-8996-1.img@100% (bootloader) devcfg-8996-1.img@100% (bootloader) lksecapp.img@100% (bootloader) cmnlib32.img@100% (bootloader) cmnlib64.img@100% (bootloader) keymaster.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) sensor_hub.img@BYPASS (bootloader) tp_SYN3708.img@BYPASS (bootloader) cs_CY8C.img@BYPASS (bootloader) splash1.nb0@BYPASS (bootloader) usb_typec_otp.img@BYPASS (bootloader) usb_typec_otp_ad.img@BYPASS ( bootloader) radio.img@BYPASS FAILED (remote: 90 hboot pre-update! please flush image again immediately ) finished. total time: 8.360s preupdate done, rebooting... Phone DISconnected Phone connected [HT676BN00159] *** Fastboot mode resending command... sending 'zip' (108168 KB)... OKAY [ 4.470s] writing 'zip'... (bootloader) HOSD CL#857212 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) WARN Skip partition_info due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 34 images from zip(zip_type=3) (bootloader) start@34 (bootloader) apppreload.img@100% (bootloader) aboot_signed.img@100% (bootloader) cota.img@100% (bootloader) xbl-8996-1.img@100% (bootloader) hosd_signed.img@100% (bootloader) apdp-8996-1.img@100% (bootloader) rpm-8996-1.img@100% (bootloader) pmic-8996-1.img@100% (bootloader) boot_signed.img@100% (bootloader) recovery_signed.img@100% (bootloader) slpi.img@100% (bootloader) adsp.img@100% (bootloader) dsp.img@100% (bootloader) rcdata.img@100% (bootloader) rfg_3.img@100% (bootloader) venus.img@100% (bootloader) modemst1.img@100% (bootloader) modemst2.img@100% (bootloader) fsc.img@100% (bootloader) tz-8996-1.img@100% (bootloader) hyp-8996-1.img@100% (bootloader) devcfg-8996-1.img@100% (bootloader) lksecapp.img@100% (bootloader) cmnlib32.img@100% (bootloader) cmnlib64.img@100% (bootloader) keymaster.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) splash1.nb0@100% (bootloader) radio.img@100% (bootloader) sensor_hub.img@BYPASS (bootloader) ERR do_firmware_update_thread: child exited with non-zero s (bootloader) tatus: 255 (bootloader) ERR Flashing [tp_SYN3708.img] failed with status [255] (bootloader) ERR Faild to update firmware [tp_SYN3708.img] (bootloader) tp_SYN3708.img@FAIL (bootloader) cs_CY8C.img@BYPASS (bootloader) usb_typec_otp.img@BYPASS (bootloader) usb_typec_otp_ad.img@BYPASS (bootloader) Update zip file OK (bootloader) ERR WRITE ERROR, 33 (bootloader) end@Done FAILED (remote: 33 RU_UPDATE_FIRMWARE_FAIL ) finished. total time: 23.769s HBoot pre-update sequence Flash process completed. Flash not successfull, reboot will not be done HBoot pre-update sequence Flash process completed. Flash not successfull, reboot will not be done | |
09-17-2018, 14:42 | #14 (permalink) |
Member: 185010 Status: Offline Sonork: alias-albertino Thanks Meter: 170 | i have wait for somedays now no body is able to find solution to this phone weather its software or hardware even the product supporters are silent. |
09-17-2018, 16:53 | #15 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | nowadays there are lots of phones with emmc damaged. u can't s-off cant flash same version firmware with matching cid and matching product id higher chances of damaged emmc you try different firmwares if fails than no other option left |
The Following User Says Thank You to deepakgarg For This Useful Post: |
