01-21-2018, 05:26 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Age: 37
Member: 906256 Status: Offline Thanks Meter: 40 | htc desire 600 repair imei2 failed Trying to connect in modem mode... Reading security info... Security is OFF Reading CID... Reading IMEI... Reading SIMLOCK info... Checking lock status: Phone is UNLOCKED SUCCESSFULLY connected repair imei1 okey Trying to repair IMEI... SUCCESS: The command was executed! but imei2 command failed and say : Trying to repair IMEI 2... Error: The phone has returned an error, command failed. Do you have smartcard inserted into the phone? You may need to S-OFF first also. plz help |
01-21-2018, 13:50 | #2 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hi, As I see there may be no command for IMEI2 in legacy mode, did you try to flash latest firmware and use direct mode (with the phone in S-OFF state) |
The Following User Says Thank You to xtc2clip For This Useful Post: |
02-11-2018, 20:30 | #3 (permalink) | |
Member: 906256 Status: Offline Thanks Meter: 40 | Quote:
use direct mode is error.write IMEI1 in legacy mode is okey fixed.plz fix this problem.tnx | |
