01-16-2017, 13:57 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: India
Member: 949240 Status: Offline Thanks Meter: 86 | htc m7 flashing error [SOLVED] my phones bootloader is locked and phone is s-off and cid 11111111 Starting flash process... target rom version: 7.18.161.51 found large-zip header, file count: 5 processing file 1/5... sending 'zip' (50225 KB)... OKAY [ 3.079s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... Error: If your phone is S-ON and bootloader is UNLOCKED you cannot flash this image. You should make S-OFF or lock/relock your bootloader FAILED (remote: 22 loading zip info fail Please check if you flash part) finished. total time: 3.612s Flash process completed. Flash not successfull, reboot will not be done Starting flash process... target rom version: 7.18.161.51 found large-zip header, file count: 5 processing file 1/5... sending 'zip' (50225 KB)... OKAY [ 3.011s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... Error: If your phone is S-ON and bootloader is UNLOCKED you cannot flash this image. You should make S-OFF or lock/relock your bootloader FAILED (remote: 22 loading zip info fail Please check if you flash part) finished. total time: 3.542s Flash process completed. Flash not successfull, reboot will not be done |
01-16-2017, 20:57 | #3 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | Quote:
where we can find partial fimware when castmber front of me, becoz we cant hold every castmber, some castmber need quick service..and some time you are not online..that time what we can do???? i see lot of htc model b4 flash ,b4 update we need to flash 1st with partical fimware... | |
The Following 2 Users Say Thank You to vickyjadhav6161 For This Useful Post: |
01-17-2017, 10:32 | #4 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
Your customers must understand, that if they want to have their phone repaired, they must wait a bit. I don't think they will find a better place to repair, than your shop partial flash files are available for download from our support. | |
The Following User Says Thank You to xtc2clip For This Useful Post: |
01-17-2017, 17:03 | #5 (permalink) |
Member: 949240 Status: Offline Thanks Meter: 86 | where are partial files available on support can u please give path Starting flash process... target rom version: 7.19.401.51 found large-zip header, file count: 5 processing file 1/5... sending 'zip' (50228 KB)... OKAY [ 3.119s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... FAILED (remote: 22 loading zip info fail Please check if you flash part) finished. total time: 3.648s Flash process completed. Flash not successfull, reboot will not be done Phone DISconnected Phone connected [HT331W900149] *** Fastboot mode reply me fast team please Last edited by xtc2clip; 01-18-2017 at 16:27. |
12-18-2018, 00:12 | #7 (permalink) | |
Freak Poster Join Date: Jan 2012
Member: 1713460 Status: Offline Thanks Meter: 28 | Quote:
Can you add partial file for m7_wlv ? Did not found on support have same error when trying to flash 6.22.605.3 on 1.10.605.10 | |
12-18-2018, 00:45 | #9 (permalink) |
Member: 1713460 Status: Offline Thanks Meter: 28 | Will answer to myself. Seems like in m7 model we can update sw only one by on. We can not update to 6.22 from 1.10 or 3.11. Only when I installed 4.10 firmware it allowed to flash full 5.28 zip |
