HTC One m8 dugl Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: INVALID_VER_INFO (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 6.16.401.101 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: HU46RWM01530 (bootloader) imei: 352272060507042 (bootloader) imei2: 352272060507059 (bootloader) meid: 00000000000000 (bootloader) product: m8_dugl (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B64000 (bootloader) cidnum: HTC__102 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: RUU (bootloader) commitno-bootloader: 76df2b54 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! Execution time is 8(ms) Reading CID information ... (bootloader) cid: HTC__102 OKAY Execution time is 2(ms) Reading MEID information ... (bootloader) meid: 00000000000000 OKAY Execution time is 2(ms) Reading IMEI1 information ... (bootloader) imei: 352272060507042 OKAY Execution time is 3(ms) Reading IMEI2 information ... (bootloader) imei2: 352272******* OKAY Execution time is 2(ms) Reading secure flag information ... (bootloader) secure_flag: 536875011 OKAY Execution time is 4(ms) Reading serial number information ... (bootloader) [ERR] Command error !!! OKAY Execution time is 2(ms) Read information completed. |
Starting flash process... found large-zip header, file count: 6 processing file 1/6... sending 'zip' (55994 KB)... OKAY [ 2.450s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... (bootloader) checking hboot version... Processing [hboot], please wait... (bootloader) total_image_number=18 Processing [hboot], please wait... (bootloader) signature checking... (bootloader) ...... Successful (bootloader) current_image_number=0 Processing [sbl1], please wait... (bootloader) signature checking... (bootloader) ...... Successful (bootloader) current_image_number=1 Processing [sbl1], please wait... (bootloader) signature checking... (bootloader) verified fail (bootloader) ..... Bypassed (bootloader) current_image_number=2 Processing [sbl1], please wait... (bootloader) signature checking... (bootloader) verified fail (bootloader) ..... Bypassed (bootloader) current_image_number=3 Processing [sdi], please wait... (bootloader) ...... Successful (bootloader) current_image_number=4 Processing [rpm], please wait... (bootloader) signature checking... (bootloader) ...... Successful (bootloader) current_image_number=5 Processing [boot], please wait... (bootloader) ...... Successful (bootloader) current_image_number=6 Processing [recovery], please wait... (bootloader) ...... Successful (bootloader) current_image_number=7 Processing [adsp], please wait... (bootloader) ...... Successful (bootloader) current_image_number=8 Processing [wcnss], please wait... (bootloader) ...... Successful (bootloader) current_image_number=9 Processing [tz], please wait... (bootloader) signature checking... (bootloader) ...... Successful (bootloader) current_image_number=10 Processing [pg2fs_spcustom], please wait... (bootloader) ...... Successful (bootloader) current_image_number=11 Processing [sensor_hub], please wait... (bootloader) ...... Successful (bootloader) current_image_number=12 Processing [tp], please wait... (bootloader) ..... Bypassed (bootloader) current_image_number=13 Processing [tp], please wait... (bootloader) ..... Bypassed (bootloader) current_image_number=14 Processing [sp1], please wait... (bootloader) ...... Successful (bootloader) current_image_number=15 Processing [radio], please wait... (bootloader) trying to rename MBA (bootloader) ...... Successful (bootloader) current_image_number=16 Processing [rcdata], please wait... (bootloader) ...... Successful (bootloader) current_image_number=17 OKAY [ 69.700s] finished. total time: 72.150s processing file 2/6... sending 'zip' (488177 KB)... OKAY [ 14.554s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... FAILED (remote: project does not have sa key to decrypt rom) finished. total time: 33.254s HBoot pre-update sequence Flash process completed. need Help Pleas !!! |
hi i'd be more than willing to help, can you please describe what the actual problem is? i still have my htc m8 and can check and help |
Thx for helping, HTC m8 boot only to ruu, after flash. |
The device should be s-off but bootloader) secure_flag: 536875011 And flashing is not complete file 2/6 and FAILED (remote: project does not have sa key to decrypt rom) Finish in 33 second's. |
first gain s-off second super cid flash partial file then flash full stock rom |
thanks, I will try, but where can I get the partial file? |
none in the support will request supporter to add it for u |
i try S-off, and Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 1 (bootloader) m8dug_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078040 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) writesecureflag: KeyCard remain count 10000 (bootloader) PID:300 (bootloader) Start Verify: 536875011 (bootloader) [PGFS] partition_update_pgfs: pg1fs_security (bootloader) TZ_HTC_SVC_ENC ret = 0 (bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery Operation finished |
i think clip was detected by phone did u see sd mounted in download mode ? |
It boots only to ruu mode, and when reboot ruu again s-off and super cid it's gone. I can't boot to fastboot menue. |
Yes it's briked HS-USB QDLoader 9008. I found something to repair the problem. https://www.droidsavvy.com/unbrick-qualcomm-mobiles/ until now without success |
Do you have an option to replace this EMMC to a new one? |
I have m8_uhl emmc repaired but blank only qdloader drivers Sent from my iPhone using Tapatalk |
