03-16-2017, 11:07 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | htc one m9 fail flash it was 7.0 os was on phone Starting flash process... target rom version: 1.03.1405.13 found large-zip header, file count: 6 processing file 1/6... sending 'zip' (261841 KB)... OKAY [ 18.057s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) ERR check AES encrypted magic string failed. (bootloader) end@Done FAILED (remote: 12 RU_ZIP_ERROR ) finished. total time: 20.107s Flash process completed. Flash not successfull, reboot will not be done Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) serialno: FA54XYJ03859 (bootloader) current-slot: (bootloader) imei: 357226065811143 (bootloader) version-main: 4.14.401.7 (bootloader) boot-mode: RUU (bootloader) version-baseband: 01.01_U114401011_117.00.61117G_2_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: HTC__016 all: Execution time is 7(ms) Reading secure flag information ... (bootloader) Device security level S-ON OKAY Execution time is 62(ms) Reading CID information ... (bootloader) cid: HTC__016 OKAY Execution time is 5(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 6(ms) Read information completed. Starting flash process... target rom version: 3.35.401.12 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (134725 KB)... OKAY [ 9.528s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) ERR check AES encrypted magic string failed. (bootloader) end@Done FAILED (remote: 12 RU_ZIP_ERROR ) finished. total time: 11.581s Flash process completed. Flash not successfull, reboot will not be done |
03-19-2017, 14:23 | #6 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello! I have re-checked your problem, and found that you need a newer flash file. So I have uploaded it for you! Please download file no 490768 and flash your phone. Let us know if you could help you. |
The Following User Says Thank You to xtc2clip For This Useful Post: |
03-20-2017, 11:36 | #7 (permalink) | |
Member: 328688 Status: Offline Thanks Meter: 2,282 | Quote:
Starting flash process... target rom version: 4.14.401.7 found large-zip header, file count: 7 processing file 1/7... sending 'zip' (134523 KB)... OKAY [ 9.479s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) Perform pre-update (bootloader) WARN Skip cmnlib32.img due to unmatched partition name (bootloader) WARN Skip cmnlib64.img due to unmatched partition name (bootloader) WARN Skip keymaster.img due to unmatched partition name (bootloader) WARN Skip bootlocker.img due to unmatched partition name (bootloader) WARN Skip cir.img due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 23 images from zip(zip_type=3) FAILED (remote: 90 hboot pre-update! please flush image again immediately ) finished. total time: 15.507s preupdate done, rebooting... Phone DISconnected resending command... < waiting for device > Phone connected [FA54XYJ03859] *** Fastboot mode sending 'zip' (134523 KB)... OKAY [ 10.744s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) Perform pre-update (bootloader) WARN Skip cmnlib32.img due to unmatched partition name (bootloader) WARN Skip cmnlib64.img due to unmatched partition name (bootloader) WARN Skip keymaster.img due to unmatched partition name (bootloader) WARN Skip bootlocker.img due to unmatched partition name (bootloader) WARN Skip cir.img due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 23 images from zip(zip_type=3) (bootloader) start@23 (bootloader) apppreload.img@BYPASS (bootloader) aboot_signed.img@100% (bootloader) cota.img@BYPASS (bootloader) sbl1-8994-1.img@100% (bootloader) sdi.img@100% (bootloader) hosd_signed.img@100% (bootloader) rpm-8994-1.img@100% (bootloader) pmic-8994-1.img@100% (bootloader) boot_signed.img@BYPASS (bootloader) recovery_signed.img@BYPASS (bootloader) adsp.img@BYPASS (bootloader) cpe.img@BYPASS (bootloader) rcdata.img@BYPASS (bootloader) modem_st1.img@BYPASS (bootloader) modem_st2.img@BYPASS (bootloader) tz-8994-1.img@100% (bootloader) hyp-8994-1.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) sensor_hub.img@BYPASS (bootloader) tp_SYN3351.img@BYPASS (bootloader) tp_MXM11876.img@BYPASS (bootloader) splash1.nb0@BYPASS (bootloader) radio.img@BYPASS FAILED (remote: 90 hboot pre-update! please flush image again immediately ) finished. total time: 14.037s preupdate done, rebooting... Phone DISconnected resending command... < waiting for device > sending 'zip' (134523 KB)... Phone connected [FA54XYJ03859] *** Fastboot mode OKAY [ 10.708s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) WARN Skip cmnlib32.img due to unmatched partition name (bootloader) WARN Skip cmnlib64.img due to unmatched partition name (bootloader) WARN Skip keymaster.img due to unmatched partition name (bootloader) WARN Skip bootlocker.img due to unmatched partition name (bootloader) WARN Skip cir.img due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 23 images from zip(zip_type=3) FAILED (remote: 90 hboot pre-update! please flush image again immediately ) finished. total time: 13.169s preupdate done, rebooting... Phone DISconnected resending command... < waiting for device > sending 'zip' (134523 KB)... Phone connected [FA54XYJ03859] *** Fastboot mode FAILED (data transfer failure (Too many links)) finished. total time: 1.300s HBoot pre-update sequence Flash process completed. Flash not successfull, reboot will not be done Phone DISconnected Phone connected [FA54XYJ03859] *** Fastboot mode | |
03-20-2017, 11:47 | #8 (permalink) |
Member: 328688 Status: Offline Thanks Meter: 2,282 | Finely done thanx u so much help Code: Starting flash process... target rom version: 4.14.401.7 found large-zip header, file count: 7 processing file 1/7... sending 'zip' (134523 KB)... OKAY [ 9.538s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) WARN Skip cmnlib32.img due to unmatched partition name (bootloader) WARN Skip cmnlib64.img due to unmatched partition name (bootloader) WARN Skip keymaster.img due to unmatched partition name (bootloader) WARN Skip bootlocker.img due to unmatched partition name (bootloader) WARN Skip cir.img due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 23 images from zip(zip_type=3) FAILED (remote: 90 hboot pre-update! please flush image again immediately ) finished. total time: 15.242s preupdate done, rebooting... Phone DISconnected resending command... < waiting for device > Phone connected [FA54XYJ03859] *** Fastboot mode sending 'zip' (134523 KB)... OKAY [ 10.321s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) WARN Skip cmnlib32.img due to unmatched partition name (bootloader) WARN Skip cmnlib64.img due to unmatched partition name (bootloader) WARN Skip keymaster.img due to unmatched partition name (bootloader) WARN Skip bootlocker.img due to unmatched partition name (bootloader) WARN Skip cir.img due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 23 images from zip(zip_type=3) (bootloader) start@23 (bootloader) apppreload.img@22% (bootloader) apppreload.img@45% (bootloader) apppreload.img@68% (bootloader) apppreload.img@90% (bootloader) apppreload.img@100% (bootloader) aboot_signed.img@100% (bootloader) cota.img@100% (bootloader) sbl1-8994-1.img@100% (bootloader) sdi.img@100% (bootloader) hosd_signed.img@100% (bootloader) rpm-8994-1.img@100% (bootloader) pmic-8994-1.img@100% (bootloader) boot_signed.img@100% (bootloader) recovery_signed.img@100% (bootloader) adsp.img@100% (bootloader) cpe.img@100% (bootloader) rcdata.img@100% (bootloader) modem_st1.img@100% (bootloader) modem_st2.img@100% (bootloader) tz-8994-1.img@100% (bootloader) hyp-8994-1.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) splash1.nb0@100% (bootloader) radio.img@100% (bootloader) sensor_hub.img@BYPASS (bootloader) tp_SYN3351.img@BYPASS (bootloader) tp_MXM11876.img@BYPASS (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 14.715s] finished. total time: 25.036s processing file 2/7... sending 'zip' (449436 KB)... OKAY [ 32.755s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_00@8% (bootloader) system.img_00@16% (bootloader) system.img_00@24% (bootloader) system.img_00@32% (bootloader) system.img_00@41% (bootloader) system.img_00@49% (bootloader) system.img_00@57% (bootloader) system.img_00@65% (bootloader) system.img_00@74% (bootloader) system.img_00@82% (bootloader) system.img_00@90% (bootloader) system.img_00@98% (bootloader) system.img_00@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 20.313s] finished. total time: 53.078s processing file 3/7... sending 'zip' (426769 KB)... OKAY [ 30.825s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_01@8% (bootloader) system.img_01@16% (bootloader) system.img_01@24% (bootloader) system.img_01@33% (bootloader) system.img_01@41% (bootloader) system.img_01@49% (bootloader) system.img_01@57% (bootloader) system.img_01@66% (bootloader) system.img_01@74% (bootloader) system.img_01@82% (bootloader) system.img_01@90% (bootloader) system.img_01@99% (bootloader) system.img_01@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 19.273s] finished. total time: 50.109s processing file 4/7... sending 'zip' (480580 KB)... OKAY [ 35.332s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_02@8% (bootloader) system.img_02@16% (bootloader) system.img_02@24% (bootloader) system.img_02@32% (bootloader) system.img_02@41% (bootloader) system.img_02@49% (bootloader) system.img_02@57% (bootloader) system.img_02@65% (bootloader) system.img_02@74% (bootloader) system.img_02@82% (bootloader) system.img_02@90% (bootloader) system.img_02@98% (bootloader) system.img_02@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 20.393s] finished. total time: 55.726s processing file 5/7... sending 'zip' (401528 KB)... OKAY [ 29.818s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_03@8% (bootloader) system.img_03@16% (bootloader) system.img_03@25% (bootloader) system.img_03@33% (bootloader) system.img_03@41% (bootloader) system.img_03@50% (bootloader) system.img_03@58% (bootloader) system.img_03@66% (bootloader) system.img_03@75% (bootloader) system.img_03@83% (bootloader) system.img_03@91% (bootloader) system.img_03@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 18.502s] finished. total time: 48.321s processing file 6/7... sending 'zip' (187927 KB)... OKAY [ 14.275s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_04@16% (bootloader) system.img_04@33% (bootloader) system.img_04@49% (bootloader) system.img_04@66% (bootloader) system.img_04@82% (bootloader) system.img_04@99% (bootloader) system.img_04@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 10.588s] finished. total time: 24.864s processing file 7/7... sending 'zip' (13480 KB)... OKAY [ 2.011s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) get 2 images from zip(zip_type=3) (bootloader) start@2 (bootloader) dzdata_32g.img@100% (bootloader) boot_signed.img@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 4.048s] finished. total time: 6.059s rompack updated HBoot pre-update sequence Flash process completed. Restarting phone... rebooting... Execution time is 6(ms) Phone DISconnected |
06-08-2017, 15:49 | #10 (permalink) | |
No Life Poster Join Date: May 2006 Location: zambia
Member: 272581 Status: Offline Thanks Meter: 118 | Quote:
06-12-2017, 16:57 | #12 (permalink) |
Junior Member Join Date: May 2009 Location: BOGOTA
Member: 1031424 Status: Offline Thanks Meter: 0 | Htc does not enter ruu reboot is not possible flash And as second step the equipment is CID 621 version Asia 490768 this file is of the European version would not serve. |
10-12-2017, 06:12 | #15 (permalink) |
No Life Poster Join Date: May 2005 Location: bridgetown Age: 59
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) imei: 357226068312396 (bootloader) version-main: 3.36.709.3 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U11440792_97.00.51203G_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: HTC__621 all: Execution time is 0(ms) Reading CID information ... (bootloader) cid: HTC__621 OKAY Execution time is 1(s) Reading MEID information ... (bootloader) meid: OKAY Execution time is 0(ms) Reading IMEI1 information ... (bootloader) imei: 357226068312396 OKAY Execution time is 15(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 31(ms) Reading secure flag information ... (bootloader) Device security level S-ON OKAY Execution time is 34(ms) Reading serial number information ... (bootloader) Device Serial No. is HT577YJ00425 OKAY Execution time is 15(ms) Read information completed. flash failed need help xtc clip team Starting flash process... target rom version: 3.36.709.3 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (277761 KB)... OKAY [ 14.809s] writing 'zip'... (bootloader) HOSD CL#676746 FAILED (remote: 9 RU_SECURITY_FAIL zip from usb command in download mode) finished. total time: 16.754s Flashing cannot be done in this mode, please reboot to RUU mode (use RUU button) and repeat flashing! Flash process completed. Flash not successfull, reboot will not be done |
