Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 12-10-2015, 11:58   #1 (permalink)
Member: 2365163
Thanks Meter: 20
HTC_One M8 MID change
Does anybody have a fast and smooth solution how to change Model ID on M8, At the moment im running Europe MID, but would like to change it into AT&T So I could get rid of the demo and perform system update in the system.
Please help
Old 12-10-2015, 12:36   #2 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
With XTC 2 Clip connected to the phone, boot to fastboot (VOL_DOWN+PWR), run XTC 2 Tool, open "Direct mode commands" and press " Write MEID". That's all!
Old 12-10-2015, 12:44   #3 (permalink)
Member: 2365163
Thanks Meter: 20
I want it to change into this MEID 0P6B12000 but it gave me an error, saying it must be 14-digits long. Sorry if i don't know the basics yet, im a beginner.
Old 12-10-2015, 13:25   #4 (permalink)
Member: 2424855
Thanks Meter: 17
follows the tutorial on XDA, not so hard, only by entering some adb commands
Old 12-10-2015, 13:37   #5 (permalink)
Member: 2365163
Thanks Meter: 20
[how to] change your MID without an eng boot… | HTC One (M8)
I tried the AT&T option, and it gave me an error stating that dd is not recognized as a command or smth. Would be much more easier if i could do it with xtc2clip.
Old 12-10-2015, 13:49   #6 (permalink)
Member: 2416253
Thanks Meter: 4,162
You have my reply, check second message in this post.
It's not a good idea to follow some xda threads, while you already have a handy tool like XTC 2 Tool.
Old 12-10-2015, 13:54   #7 (permalink)
Member: 2365163
Thanks Meter: 20
I tried it with direct mode already, had an error:Error: MEID must be 14 digits
Old 12-10-2015, 13:56   #8 (permalink)
Member: 2416253
Thanks Meter: 4,162
Sorry, I was talking about MEID, not MID.
As to MID - don't do this. You can do it in fastboot mode by using 'oem writemid XXXXXXXX", but I do NOT recommend you to do this.
Firmwares are NOT interchangeable, so, for example, M8_UL cannot be properly flashed to M8_WHL, etc.
The Following 3 Users Say Thank You to xtc2clip For This Useful Post:
Old 12-10-2015, 14:13   #9 (permalink)
Member: 2365163
Thanks Meter: 20
So the only solution to get rid of demo, is to still use supercid and unlocked/developer ruu? There is only android 5.0.2 version out there of unlocked version. But i need 6.0 , so the system would say"there are no updates" instead of "software is modified"
Old 12-10-2015, 14:38   #10 (permalink)
Member: 2365163
Thanks Meter: 20
I also tried this command 'oem writemid XXXXXXXX" because i have nothing to lose, but it still gave me an error
Old 12-10-2015, 15:09   #11 (permalink)
Member: 2416253
Thanks Meter: 4,162
Did you try just to flash the M8 6.0 firmware?
Old 12-10-2015, 15:14   #12 (permalink)
Member: 2365163
Thanks Meter: 20
No, i don't have 6.0 ruu.exe
The Following User Says Thank You to Sukavanucci For This Useful Post:
Old 12-10-2015, 17:13   #13 (permalink)
Member: 2416253
Thanks Meter: 4,162
Does it exist at all? Are you saying that ATT M8 has 6.0?
Old 12-11-2015, 11:28   #14 (permalink)
Member: 2365163
Thanks Meter: 20
I just need a solution to change model id into at&t , so when i give the phone at&t cid, it will update itself in the system. I don't know if 6.0 is out as a ruu. But i know that m8-s will get 6.0
Old 12-11-2015, 11:57   #15 (permalink)
Member: 737720
Thanks Meter: 1,421
Bro 6.0 is not out for m8 or m9. If u want u can install custom Rom. And chk ur bootloader is lock or unlock. If it is unlock then lock the bootloader. So u can have Ota when is out
Page generated in 0.22699 seconds with 8 queries
