Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 07-01-2015, 15:39   #1 (permalink)
Member: 2416253
Thanks Meter: 4,162
Thumbs up IMPORTANT: How to repair filesystem after format, etc
Hello,
IMPORTANT: Starting from XTC 2 Tool version 1.38 you no longer need to download win32diskimager and follow this guide! This option is built-in into XTC 2 Tool software@
NOTE: August 25, a new image has been uploaded. It will prevent Android from creating system files.
Many customers are trying to format the clip with wrong fs, which leads to a corrupted file system.
File system can also be corrupted by the wrong ejection from USB, etc.
We have a procedure that you may use to restore your clip to factory state:
1) Download this application:
Download Win32 Disk Imager from SourceForge.net
2) Download filesystem image:
https://xtc2.net/downloads/image2017s.img (short version, faster flashing)
https://xtc2.net/downloads/image2015.img (full version, in case short doesn't help)
3) Run Win32 Disk Imager
4) In the "Image file" select downloaded "image2015.img"
5) Connect XTC2Clip to the microSD reader.
6) Select the correct disk drive in the "Device" droplist. WARNING! Make a careful selection. If you choose a wrong drive, you can erase data on one of your disks.
7) Press "Write" and wait for the operation to complete. It may take 1-2 minutes.
8) Reconnect clip
Done. Please recreate the files you need (e.g. sf.txt, etc) and you may start using the clip as usual.
here the simple steps of animation video :
Last edited by xtc2clip; 04-17-2019 at 15:05. Reason: Updated links with secure connection
The Following 36 Users Say Thank You to xtc2clip For This Useful Post:
Old 07-02-2015, 19:38   #2 (permalink)
Member: 495719
Thanks Meter: 8
i tried to flash it it giving me error
an error occurrd when attempting to write data to handle error 23 data error (cyclic redundancy check)
Old 07-02-2015, 19:40   #3 (permalink)
Member: 2416253
Thanks Meter: 4,162
Change sdreader, reboot pc, reconnect everything and try again.
The Following 2 Users Say Thank You to xtc2clip For This Useful Post:
Old 07-09-2015, 21:19   #4 (permalink)
Crazy Poster
Member: 2247535
Thanks Meter: 2
I get this
Error 1117: The request could not be performed because of an I/O device error
Old 07-10-2015, 09:37   #5 (permalink)
Member: 2416253
Thanks Meter: 4,162
Originally Posted by mk256 View Post
I get this
Old 07-10-2015, 12:54   #6 (permalink)
Crazy Poster
Member: 2247535
Thanks Meter: 2
I did them all but still the same error
Old 07-10-2015, 21:49   #7 (permalink)
Crazy Poster
Member: 2247535
Thanks Meter: 2
after several attempts its solved now!!!
thanks
The Following User Says Thank You to mk256 For This Useful Post:
Old 07-25-2015, 12:22   #8 (permalink)
Member: 2070850
Thanks Meter: 9
pleaseee set image file
Old 07-26-2015, 10:12   #9 (permalink)
Member: 2416253
Thanks Meter: 4,162
Sorry?
Old 07-29-2015, 12:06   #10 (permalink)
gsmrazvan's Avatar
Member: 26714
Thanks Meter: 14
the img file is mising from support or support is down or file corupted unable to download image.img from link
Old 07-29-2015, 14:01   #11 (permalink)
Member: 2416253
Thanks Meter: 4,162
Here is an alternate link for you:
image.img
The Following 5 Users Say Thank You to xtc2clip For This Useful Post:
Old 08-01-2015, 21:20   #12 (permalink)
Member: 2437650
Thanks Meter: 4
thanks for the tutorial xtc2clip. it really helped a lot.
Old 08-10-2015, 15:54   #13 (permalink)
..RISHI..'s Avatar
Member: 868990
Sonork: 100.1615913
Thanks Meter: 23
Hello,
http://xtc2.net/downloads/image.img
4) In the "Image file" select downloaded "image.img"
8) Reconnect clip
how to recreate the sf.txt file i have formatted my xtc2clip i am new user for xtc2clip
The Following 4 Users Say Thank You to ..RISHI.. For This Useful Post:
Old 08-10-2015, 16:20   #14 (permalink)
Member: 2416253
Thanks Meter: 4,162
sf.txt is just a file with settings. Use XTC2Clip Tool to create the settings you need.
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 09-30-2015, 06:05   #15 (permalink)
Member: 2461053
Help me...!!!
"An error ocurred when attempting to write data to handle.
Error 2: El sistema no puede encontrar el archivo especificado".
PC formatted. No applications. No antivirus. What do I do?
NOTE: Please answer in spanish.
The Following User Says Thank You to eze021188 For This Useful Post:
Page generated in 0.22443 seconds with 8 queries
