Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 11-08-2017, 16:51   #1 (permalink)
Member: 2616876
Thanks Meter: 2
HTC M9 + does the process well but does not repair imei
Hello
Dear customers,
Since many users are confused about M9 + / E9 + / One ME IMEI repair, here is a manual how to do this:
1. Connect XTC 2 Clip to the computer.
2. Run XTC 2 Tool, go to "SD moderator", check "New IMEI" and "New IMEI2" (if you need to repair IMEI2 also), enter new values ​​and click "Save to drive"
3. Go to "M9 + / E9 + / ..." tab and press "Copy files for M9 + / E9 + / Desire 820s"
4. Follow the regular unlock procedure. The unlock scripts will detect IMEI files and write new IMEI.
I already followed that process is successful and before but when turning on the equipment the imei is the same, it does not change
Use version 1.33 last also 1.32 and 1.25 and the same thing happens
Device data: HTC 0PK7110 9pw
version of Android 6.0 patch security 1 October 2016
PS the process of unlocking bootloader if you do it right but the imei's is false
please help
Old 11-08-2017, 18:06   #2 (permalink)
Member: 652685
Sonork: 100.1594842
Thanks Meter: 45
check for unknown baseband.
Old 11-09-2017, 14:31   #3 (permalink)
Member: 2616876
Thanks Meter: 2
Baseband is ok................................
Old 11-10-2017, 16:40   #4 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
Can you send me your xtc2log.txt from your clip to PM or Skype?
Old 03-07-2019, 22:50   #5 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
Originally Posted by xtc2clip View Post
Hello,
i have the same issue, i have could not repair imei HTC M9+ 0PK7110
Any solution?
Old 03-07-2019, 23:14   #6 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
Any solution?
Already fixed.
1. Repair xtc file 2015 + repair xtc file 2017
2. repair process (copy files + new imxx to xtc)
3. thatīs all. full repaired.
Page generated in 0.18522 seconds with 9 queries
