Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 05-26-2019, 00:50   #1 (permalink)
Member: 728011
i want xtc team help me
i have xtc
but not can do any opration
all faild
i have d630n
i want to make s off but fail
i want to remove fro but fail
Sending oem writesecureflag 0
... (bootloader) SecuritySDInit: counter = 2
(bootloader) a16dwg_init_sd, SD card already power on
(bootloader) a16dwg_init_sd, SD card io already power on
(bootloader) sdhci_open: id=0
(bootloader) Initializing MMC host data structure and clock!
(bootloader) mmc slot#2 clock enabled
(bootloader) sdhci_set_clock: slot 2, freq 192000000
(bootloader) GPLL0 is enabled
(bootloader) clock_update_cfg_sd is done
(bootloader) sd clock set done
(bootloader) sdhci_set_bus_width: bus width 0
(bootloader) sdhci_clk_supply: freq 400000
(bootloader) Error: Command never completed
(bootloader) Error: Command timeout error
(bootloader) Error: Command completed with errors
(bootloader) The response for CMD8 does not match the supplied value
(bootloader) Decoded CID fields:
(bootloader) Manufacturer ID: 7f
(bootloader) OEM ID: 0x0
(bootloader) Product Name: 5270
(bootloader) Product revision: 5.2
(bootloader) Product serial number: B4E
(bootloader) Manufacturing date: 2 2015
(bootloader) sdhci_clk_supply: freq 50000000
(bootloader) sdhci_set_bus_width: bus width 1
(bootloader) Done initialization of the card
(bootloader) erase_grpsize: 0
(bootloader) erase_grpmult: 96
(bootloader) wp_grpsize: 1
(bootloader) wp_grpen: 1
(bootloader) perm_wp: 0
(bootloader) temp_wp: 0
(bootloader) Error: DATA time out error
(bootloader) Failed Reading block @ 0
(bootloader) [SD_ERR] sd_read_sector: read sector failed (0 1)
(bootloader) [Tuxera][Error] Failed to read MBR
(bootloader) [FAT_ERROR] fat_open_file: load bpb fail(-5)
(bootloader) [JAVACARD_ERR] SMART_IO.CRD cann't find
(bootloader) writesecureflag: Permission denied, value 1
OKAY
finished. total time: 44.070s
htc_fastboot finished
Operation finished
Phone DISconnected
Old 05-26-2019, 19:38   #2 (permalink)
Member: 728011
no body here
i have more devices
i cant do s off or cid
only hang phone with sd flex
i born image and change reader and flex
help
Old 05-27-2019, 20:23   #3 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
Does it happen on one phone or on all phones?
Old 05-28-2019, 03:41   #4 (permalink)
Member: 728011
All phones ans all model
Old 05-28-2019, 13:28   #5 (permalink)
Member: 728011
Old 05-28-2019, 19:59   #6 (permalink)
Member: 2416253
Thanks Meter: 4,162
Originally Posted by hossamfox View Post
According to the log - there is a problem in communication.
If you did the filesystem repair and you sure that flex is OK, the last thing you can try is to open the clip and carefully resolder EEPROM chip. We had several reports when this operation helped.
Sorry for troubles.
Page generated in 0.13657 seconds with 8 queries
