07-16-2015, 20:07 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: iran Age: 46
Member: 652684 Status: Offline Thanks Meter: 20 | hel my clip does not work error getting card information.probably you need to update your card.please update your card,if this option is not available- please contact support and there is no update for my clip and i repair it with file sistem but not work plz help what cani do? |
07-16-2015, 21:03 | #2 (permalink) |
Member: 652684 Status: Offline Thanks Meter: 20 | when i wanto s-off any phone in offline mode in fast boot this error hapend open name file error chek keycard faied what is this? i am so sad about it plz help suporter |
07-17-2015, 11:24 | #6 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Solve this issue plz...i gone through all Manuals & Procedures. Reseller is not replying me BR Last edited by mobile_hotman; 07-17-2015 at 11:31. |
07-17-2015, 11:40 | #9 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Please connect clip in XTC2Tool to make sure service files are correct. Go to SD tab and press "Read from drive" button. Again - I recommend you to eject and put the smartcard back, here is the manual how to insert smartcard correctly: http://forum.gsmhosting.com/vbb/f961.../#post11140745 |
07-17-2015, 11:45 | #10 (permalink) | |
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
NO settings found on your SD Card. BR | |
07-17-2015, 14:21 | #13 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | You can also do a small test - save any config file like sf.txt or imei.txt (just use XTC2Tool for this), and use it with any phone in offline (SD) mode. If your phone will see the files but will say check keycard failed, then probably there is no communication with the card. Or better is to use direct mode for any operation (like change cid, etc) and post complete log here. You can also try another PC, but I don't thing it's going to change the situation. |
07-17-2015, 14:28 | #14 (permalink) | |
Im trying to contact re seller he is not replying me. BR | |
07-17-2015, 14:47 | #15 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Please do what I wrote - try to perform any operation in direct mode (with clip connected to your phone and phone connected to PC), and post the log from XTC2Tool here. |
