10-26-2019, 10:49 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | htc m9 error flashing bricked, how fix???? xtc2clip even read information fail, so no unlock bootloader. hope xtc2clip admins will support thanks i try to write hosd_signed_himaul.img Starting flash process... found large-zip header, file count: 1 processing file 1/1... sending 'zip' (24136 KB)... OKAY [ 0.822s] writing 'zip'... FAILED (remote: cannot flash this partition in s-on state) finished. total time: 0.841s Flash process completed. Phone DISconnected Phone connected [FA57PYJ00625] *** Fastboot mode soff error Sending oem writesecureflag 0 ... FAILunknown command FAILED (remote: unknown command) finished. total time: 0.015s htc_fastboot finished Operation finished Starting flash process... found large-zip header, file count: 1 processing file 1/1... sending 'zip' (24136 KB)... OKAY [ 0.853s] writing 'zip'... FAILED (remote: cannot flash this partition in s-on state) finished. total time: 0.869s Traceback (most recent call last): File "C:\Python34\lib\multiprocessing\queues.py", line 244, in _feed File "C:\Python34\lib\multiprocessing\connection.py ", line 200, in send_bytes File "C:\Python34\lib\multiprocessing\connection.py ", line 280, in _send_bytes BrokenPipeError: [WinError 232] The pipe is being closed Flash process completed. no download mode, no recovery mode, only fastboot mode any solution ? |
10-27-2019, 15:49 | #3 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, You can't S-OFF in bootloader mode. You are trying to flash ZIP, this is WRONG. You must flash only hosd, you should use it with fastboot: fastboot.exe flash hosd <filename.img> |
