PM3511000 pattern unlock but cant reset with hand Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5a (bootloader) version-bootloader: 1.72.0000 (bootloader) version-baseband: 3.1204.171.33 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2.18.707.5 (bootloader) serialno: FA31RW100803 (bootloader) imei: 353567052552933 (bootloader) product: enrc2b_u (bootloader) platform: HBOOT-T30S (bootloader) modelid: PM3511000 (bootloader) cidnum: HTC__038 (bootloader) battery-status: good (bootloader) battery-voltage: 3850mV (bootloader) devpower: 65 (bootloader) partition-layout: None (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: None (bootloader) hbootpreupdate: 2 (bootloader) gencheckpt: 0 all: Done! Execution time is 436(ms) Reading CID information ... (bootloader) DEBUG: cid: HTC__038 OKAY Execution time is 109(ms) Reading MEID information ... (bootloader) [ERR] Command error !!! OKAY Execution time is 140(ms) Reading IMEI1 information ... (bootloader) DEBUG: imei: 353567052552933 OKAY Execution time is 1(s) Reading IMEI2 information ... (bootloader) [ERR] Command error !!! OKAY Execution time is 15(ms) Reading secure flag information ... (bootloader) DEBUG: secure_flag: 3 OKAY Execution time is 124(ms) Reading serial number information ... (bootloader) [ERR] Command error !!! OKAY Execution time is 1(s) Read information completed. |
try command Code: fastboot -w |
erasing 'userdata'... FAILED (remote: not allowed) finished. total time: 0.016s |
try flashing if failed than emmc is write protected |
only one file on support 332234 you will need super cid to flash |
target rom version: 2.17.708.3 found large-zip header, file count: 3 processing file 1/3... sending 'zip' (13881 KB)... OKAY [ 1.692s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) time: 62 (bootloader) rom parsing finish ... (bootloader) Your memory size = 59640MB, choose rawpt_64g.img (bootloader) checking model ID... (bootloader) checking custom ID... FAILED (remote: 42 custom id check fail) finished. total time: 2.792s Flash process completed. Flash not successfull, reboot will not be done |
make it 11111111 |
bcoz i am in new in xtc clip and adopter have alredy |
use sdmode and no adapter required |
