02-19-2020, 17:05 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Iran < Milad.B >
Member: 1784663 Status: Offline Sonork: 100.1618770 Thanks Meter: 62 | problem with s-off operation,recativation problem?! Code: htc_fastboot finished 2/19/2020 11:14:47 AM Operation finished 2/19/2020 11:14:58 AM Sending oem writesecureflag 0 2/19/2020 11:14:59 AM ... (bootloader) SecuritySDInit: counter = 4 (bootloader) a5ul_init_sd, SD card already power on (bootloader) a5ul_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 2/19/2020 11:15:00 AM (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 0 (bootloader) erase_grpmult: 0 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found 2/19/2020 11:15:03 AM (bootloader) [JAVACARD_ERR] get Decrease Renew Cycle fail, SW= 6986 (bootloader) writesecureflag: Permission denied, value 8 OKAY i seracherd for this problem and fiund that need to reactivate my xtc2clip. i sent my xtc2clip's sn to admin ;please prepair it to reactive my xtc2clip using xtc client v1.5 thank u for support <3 |
