[Request] Help Unlocking HTC One M7, M9 and Y-Cable Hello, I am trying to unlock my HTC One M9 T-Mobile phone. I do not see simlock under options when I try to unlock it when the device is directly connected into the phone. Many of the posts I see are from years ago with a different firmware. The phone is version 7.0 of Android. In addition, what is when set up for the y-cable? When I connect my y-cable my computer does not detect the XTC2Clip box. Is this how it should be set up Y
I also have an M7 I need to unlock and since it does not have a SD card reader I need to figure out the y cable so I may move forward with that as well. imgur (dot) com /a/lmZld2q |
In ur pic I see SD mountet, so ur phone m9 has mount the xtx2clip. |
for m9 use special unlock tab selecting correct model and follow instructions |
I copy the files onto the box but when I tried to do simlock tool this is what I see. imgur (dot) com /OfnpoWH |
i think simlock menu should not come on screen make repair clip and try again http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ |
I did this but now I can't boot to FTM, when I use the XTC2Clip software to go into this mode the phone reboots and turns on. |
Did u try sim now ? Check if unlocked or not Check clip if log txt created Sent from my iPhone using Tapatalk |
I put a new sim and it looks fine, but in download mode it still says LOCKED. |
I tried it on a Spring M9, but after it still says sim locked. |
Sprint m9 use sprint tab Sent from my iPhone using Tapatalk |
I did, but after following the instructions it doesn't seem to be unlocked. |
when unlock is success do not reset phone as per last instruction in software insert gsm sim and select gsm option in network options |
I just wonder if you finally could S-OFF your phone? |
For the M7, no. M9 yes. |
