11-08-2018, 01:29 | #1 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Cuba Age: 36
Member: 1892086 Status: Offline Sonork: 1671742 Thanks Meter: 282 | U11 Life and power adapter |
11-08-2018, 07:40 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | U11 Life and power adapter Quote:
Change flex and try Check if clip connected to phone correctly Sent from my iPhone using Tapatalk | |
11-08-2018, 17:52 | #3 (permalink) |
Member: 1892086 Status: Offline Sonork: 1671742 Thanks Meter: 282 | thanks for your replay, i have 9 new flex cables and all cables are tested in others htc and works perfectly, the problem is this U11 Life dont recognized any of this, dont know why, and when i insert a simple sd to device works good |
11-08-2018, 21:17 | #5 (permalink) |
Member: 1892086 Status: Offline Sonork: 1671742 Thanks Meter: 282 | sir, iam an expericed user with your tool, iam trying to unlock, when device enter to download you flex is not mounted, tried with 9 diferent flex brand new cables that actually works on others htc, even tried your flex with device started, still dont reconized, when i put an ordinary sd card device sees it very good, the problem is the flex with this device, i dont know why |
11-09-2018, 14:55 | #6 (permalink) | |
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
can be some firmware protection bcoz this is first case of clip not detected by particular phone | |
11-10-2018, 05:33 | #7 (permalink) | |
Member: 1892086 Status: Offline Sonork: 1671742 Thanks Meter: 282 | Quote:
then tried with this version RUU_OCEAN_LIFE_UL_O80_SENSE90GP_MR_TMOUS_2.15.531. 11.exe and device still dont recognize the flex of xtc, i have prove of the same 9 XTC cables working on another htc. if you like i can make a video for that for you to see | |
11-11-2018, 13:38 | #8 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello! If you have problem with detecting XTC 2 Clip on U11 Life please do this: 1. Run XTC 2 Tool and open "Special unlock/IMEI" tab. 2. Select HTC 10 (Android 6&7) or HTC 10 Android 8 and press Copy files 3. Now select "Power Adapter Tools" and copy files for your model (U11 Life) 4. Insert clip into the phone, reboot to download mode and confirm that you see "SD MOUNTED" message. 5. If you see it - you can now repeat your unlock/IMEI repair operation. |
