Sprint conversion FAQ Dear customers, This guide will explain you how to use the new "A9 Sprint" conversion feature: WARNING! This procedure will erase your data. We are not responsible for any damage made to the phone during this process! Please make it at your own risk! 1. Set your phone to S-OFF and CID to 11111111 2. Connect XTC 2 Clip to your PC, run XTC 2 Tool and open "Special unlock / IMEI" tab. 3. Select "A9 / A9 Sprint" and check the "Convert Sprint A9 to European A9" checkbox 4. Press "Copy files" 5. Follow the "Step 2." instructions as usual (insert XTC 2 Clip into A9 and reboot to FTM). 6. Now flash this flash file #458831 (download from our support site) 7. Do master reset 8. Done. Wait for the phone to boot up. WARNING! To receive OTA you should change CID to original, for example BS__US001 |
Can the conversion go in the other direction, or be reversed? |
Wow. That's awesome work. Any such luck with Sprint M9? Thanks |
Very clearly understand thank you sor posting the proceder |
pls inform! WBR |
I tried the process above for the A9 (with BS_US001 M9 firmware) and after the install the baseband is lost and so is the IMEI. This is easily restored with Sprint firmware though. Hope that helps and looks forward to further development :) Thanks |
thanks for the procedure it worked fine,i would like to know if i can install otas,it will make the search and notify but i dont want to end with a brick . it will install it like any other phone with any other update?? or should i first turn s-on?? |
After the conversion the phone will behave like normal, so you should be able to receive & install OTA. S-OFF does not usually prevent from receiving OTA, so no need to set S-ON. |
I get an OTA Update but can install the OTA update cause It say I have a defference ROM version. :( So can us update OTA this A9 Sprint Conversion? Anw thanks for awesome conversion. |
From our point of view after conversion you should be able to get and install OTA with no problem. |
it says:we have determined that your phone may be running a modifies version of its system software,for your protection we caannot update your phone,please revert your phone to the offical htc system to update your phone ,if you did not modify your system software or would like help reverting your system ,please contact us via the support section at HTC United States |
Dear, Where i can find the flash file (#458831)? Thanks, |
You can get the files from support.xtc2.net |
