Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 07-17-2017, 16:58   #1 (permalink)
Member: 946381
Thanks Meter: 150
HTC ONE M9 OPJA200 after flash non official firmware imei and baseband gone-help me
customer flashed non officail firmware-now imei and baseband unknown-details as below
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) kernel: lk
(bootloader) product: htc_himauhl
(bootloader) version: 1.0
(bootloader) imei: 355378060810711
(bootloader) version-main: 1.32.401.8
(bootloader) boot-mode: download
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 0PJA10000
(bootloader) cid: 11111111
all:
Execution time is 15(ms)
Reading secure flag information
... (bootloader) Device security level S-OFF
OKAY
Execution time is 93(ms)
Reading CID information
... (bootloader) cid: 11111111
OKAY
Reading MEID information
... (bootloader) meid: 99000502696354
OKAY
Execution time is 46(ms)
Read information completed.
i tried officail firmware flashing-error as below
why above error-help me for flashing officail firmware-i think after flash imei and baseband ok.
help me for the steps
Old 07-17-2017, 17:59   #2 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
You need to flash partial flash file first, I will upload it for you and let you know.
Old 07-17-2017, 18:50   #3 (permalink)
Member: 2416253
Thanks Meter: 4,162
I have uploaded file no. 490768 for you.
Please download, flash it, and then full flash.
Old 07-18-2017, 05:43   #4 (permalink)
Member: 946381
Thanks Meter: 150
490768 FILE FLASH LOG AS BELOW
Starting flash process...
target reported max download size of 800000000 bytes
sending 'zip' (135348 KB)...
OKAY [ 8.625s]
writing 'zip'...
(bootloader) HOSD CL#506785
(bootloader) GPT is up-to-dated. [17408]
(bootloader) Perform pre-update
(bootloader) start@24
(bootloader) apppreload.img@BYPASS
(bootloader) aboot_signed.img@100%
(bootloader) dzdata_32g.img@BYPASS
(bootloader) sbl1-8994-1.img@100%
(bootloader) sdi.img@100%
(bootloader) hosd_signed.img@100%
(bootloader) rpm-8994-1.img@100%
(bootloader) pmic-8994-1.img@100%
(bootloader) boot_signed.img@BYPASS
(bootloader) recovery_signed.img@BYPASS
(bootloader) adsp.img@BYPASS
(bootloader) cpe.img@BYPASS
(bootloader) rcdata.img@BYPASS
(bootloader) modem_st1.img@BYPASS
(bootloader) modem_st2.img@BYPASS
(bootloader) tz-8994-1.img@100%
(bootloader) hyp-8994-1.img@100%
(bootloader) bootlocker.img@BYPASS
(bootloader) pg2fs_ship_signkey.img@BYPASS
(bootloader) sensor_hub.img@BYPASS
(bootloader) tp_SYN3351.img@BYPASS
(bootloader) tp_MXM11876.img@BYPASS
(bootloader) splash1.nb0@BYPASS
(bootloader) radio.img@BYPASS
FAILED (remote: FAIL90 hboot pre-update! please flush image again immediate)
finished. total time: 9.500s
Phone DISconnected
HBoot pre-update sequence
Flash process completed.
Restarting phone...
Phone connected [FA53YFJ00334] *** Fastboot mode
THEN I FULL flash-logs as below
target rom version: 4.28.401.3
found large-zip header, file count: 7
processing file 1/7...
sending 'zip' (134760 KB)...
OKAY [ 8.922s]
writing 'zip'...
(bootloader) HOSD CL#836547
(bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408]
(bootloader) WARN Skip cmnlib32.img due to unmatched partition name
(bootloader) WARN Skip cmnlib64.img due to unmatched partition name
(bootloader) WARN Skip keymaster.img due to unmatched partition name
(bootloader) WARN Skip bootlocker.img due to unmatched partition name
(bootloader) WARN Skip cir.img due to unmatched partition name
(bootloader) WARN Skip backup_android-info.txt due to unmatched partitio
(bootloader) n name
(bootloader) get 23 images from zip(zip_type=3)
(bootloader) start@23
(bootloader) apppreload.img@22%
(bootloader) apppreload.img@45%
(bootloader) apppreload.img@68%
(bootloader) apppreload.img@90%
(bootloader) apppreload.img@100%
(bootloader) cota.img@100%
(bootloader) boot_signed.img@100%
(bootloader) recovery_signed.img@100%
(bootloader) adsp.img@100%
(bootloader) cpe.img@100%
(bootloader) rcdata.img@100%
(bootloader) modem_st1.img@100%
(bootloader) modem_st2.img@100%
(bootloader) pg2fs_ship_signkey.img@100%
(bootloader) splash1.nb0@100%
(bootloader) radio.img@100%
(bootloader) sensor_hub.img@0%
(bootloader) sensor_hub.img@10%
(bootloader) sensor_hub.img@20%
(bootloader) sensor_hub.img@30%
(bootloader) sensor_hub.img@40%
(bootloader) sensor_hub.img@45%
(bootloader) sensor_hub.img@55%
(bootloader) sensor_hub.img@65%
(bootloader) sensor_hub.img@75%
(bootloader) sensor_hub.img@85%
(bootloader) sensor_hub.img@95%
(bootloader) sensor_hub.img@100%
(bootloader) Update zip file OK
(bootloader) end@Done
OKAY [ 79.938s]
finished. total time: 88.859s
processing file 2/7...
sending 'zip' (447928 KB)...
OKAY [ 27.766s]
writing 'zip'...
(bootloader) get 1 images from zip(zip_type=3)
(bootloader) start@1
(bootloader) system.img_00@8%
(bootloader) system.img_00@16%
(bootloader) system.img_00@24%
(bootloader) system.img_00@32%
(bootloader) system.img_00@41%
(bootloader) system.img_00@49%
(bootloader) system.img_00@57%
(bootloader) system.img_00@65%
(bootloader) system.img_00@74%
(bootloader) system.img_00@82%
(bootloader) system.img_00@90%
(bootloader) system.img_00@98%
(bootloader) system.img_00@100%
OKAY [ 21.703s]
finished. total time: 49.469s
processing file 3/7...
sending 'zip' (432520 KB)...
OKAY [ 26.969s]
writing 'zip'...
(bootloader) system.img_01@8%
(bootloader) system.img_01@16%
(bootloader) system.img_01@24%
(bootloader) system.img_01@33%
(bootloader) system.img_01@41%
(bootloader) system.img_01@49%
(bootloader) system.img_01@58%
(bootloader) system.img_01@66%
(bootloader) system.img_01@74%
(bootloader) system.img_01@82%
(bootloader) system.img_01@91%
(bootloader) system.img_01@99%
(bootloader) system.img_01@100%
OKAY [ 17.828s]
finished. total time: 44.797s
processing file 4/7...
sending 'zip' (471561 KB)...
OKAY [ 29.328s]
writing 'zip'...
(bootloader) system.img_02@8%
(bootloader) system.img_02@16%
(bootloader) system.img_02@24%
(bootloader) system.img_02@32%
(bootloader) system.img_02@41%
(bootloader) system.img_02@49%
(bootloader) system.img_02@57%
(bootloader) system.img_02@65%
(bootloader) system.img_02@74%
(bootloader) system.img_02@82%
(bootloader) system.img_02@90%
(bootloader) system.img_02@98%
(bootloader) system.img_02@100%
OKAY [ 18.469s]
finished. total time: 47.797s
processing file 5/7...
sending 'zip' (409251 KB)...
OKAY [ 25.500s]
writing 'zip'...
(bootloader) system.img_03@8%
(bootloader) system.img_03@16%
(bootloader) system.img_03@24%
(bootloader) system.img_03@33%
(bootloader) system.img_03@41%
(bootloader) system.img_03@49%
(bootloader) system.img_03@58%
(bootloader) system.img_03@66%
(bootloader) system.img_03@74%
(bootloader) system.img_03@82%
(bootloader) system.img_03@91%
(bootloader) system.img_03@99%
(bootloader) system.img_03@100%
OKAY [ 18.250s]
finished. total time: 43.750s
processing file 6/7...
sending 'zip' (204212 KB)...
OKAY [ 13.297s]
writing 'zip'...
(bootloader) system.img_04@15%
(bootloader) system.img_04@30%
(bootloader) system.img_04@45%
(bootloader) system.img_04@61%
(bootloader) system.img_04@76%
(bootloader) system.img_04@91%
(bootloader) system.img_04@100%
OKAY [ 10.625s]
finished. total time: 23.922s
processing file 7/7...
sending 'zip' (13483 KB)...
OKAY [ 1.828s]
writing 'zip'...
(bootloader) get 2 images from zip(zip_type=3)
(bootloader) dzdata_32g.img@100%
OKAY [ 6.141s]
finished. total time: 7.969s
rompack updated
Restarting phone...
rebooting...
Phone DISconnected
still big problem """"imei and baseband unknown"""-now phone in officail firmware-but same problem as in non officail firmware imei and baseband unknown
what i do as a next step?
help me
Old 07-18-2017, 13:48   #5 (permalink)
Member: 946381
Thanks Meter: 150
supporters waiting--any chance to revive ?
Old 07-19-2017, 06:23   #6 (permalink)
Member: 946381
Thanks Meter: 150
tried as ur pm message-error as below
C:\android>fastboot oem erase modemst1
(bootloader) [ERR] Command error !!!
OKAY [ 0.047s]
finished. total time: 0.047s
OKAY [ 0.000s]
finished. total time: 0.000s
C:\android>fastboot oem erase modemst2
OKAY [ 0.000s]
info as below
(bootloader) serialno: FA53YFJ00334
(bootloader) current-slot:
(bootloader) version-main: 4.28.401.3
(bootloader) version-baseband: 01.01_U114401011_117.00.61117G_2_F
all:
OKAY
OKAY
OKAY
Execution time is 1(s)
Old 07-19-2017, 18:13   #7 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hi. See my reply in PM please.
Old 07-01-2018, 10:25   #8 (permalink)
Member: 1787230
Thanks Meter: 4
IMEI and Baseband Unknown.
exactly same problem with me. Please help me to solve..
oem erase modem command is not working with me too.
(bootloader) serialno: FA53YFJ00672
(bootloader) imei: 355378060824944
(bootloader) version-main: 4.14.401.7
all:
OKAY
Execution time is 12(ms)
OKAY
Execution time is 11(ms)
Reading IMEI1 information
... (bootloader) imei: 355378060824944
OKAY
Reading IMEI2 information
... (bootloader) imei2:
OKAY
OKAY
Reading serial number information
... (bootloader) Device Serial No. is FA53YFJ00672
OKAY
Old 07-01-2018, 10:38   #9 (permalink)
Member: 2487890
Thanks Meter: 72
all:
OKAY
OKAY
OKAY
OKAY
OKAY
OKAY
TRY THE COMMAND BELOW
fastboot reboot-bootloader
fastboot erase persist
Old 07-02-2018, 07:32   #10 (permalink)
Member: 1787230
Thanks Meter: 4
erase persist is okay, but still baseband and imei unknown.
Old 07-02-2018, 07:53   #11 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
did u flash stock rom ?
Old 07-02-2018, 08:47   #12 (permalink)
Member: 1787230
Thanks Meter: 4
yes phone is in stock rom
Old 07-02-2018, 10:29   #13 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
try flash higher version first partial than full firmware
Old 07-02-2018, 11:45   #14 (permalink)
Member: 1787230
Thanks Meter: 4
i have already flased several images. I have sent you friend request in skype. can we chat in skype ?
Old 07-02-2018, 12:49   #15 (permalink)
Member: 988173
Thanks Meter: 23
because you had 8 on it and you put 7 you have to update it to 8 ota, and I had that problem and so i updated ota and restored imei
Page generated in 0.24632 seconds with 8 queries
