Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 02-14-2020, 18:27   #1 (permalink)
Member: 2416253
Thanks Meter: 4,162
XTC 2 Client 1.5 - please upgrade to service your clips
Dear customers,
Should you need to check/upgrade/activate your XTC 2 Clip, please download latest version of XTC 2 Client v1.5
https://mega.nz/#!7pdVhKAS!8-Nln_Hpb...hdGbF3r03BzymE
Please use version 1.5b if you have issues with Windows 8 or Windows 10:
https://mega.nz/file/7h8zybpI#pkQukW...AvcSmAcyWB-0Zk
Previous version 1.4 or older can no longer connect to the server.
The Following 5 Users Say Thank You to xtc2clip For This Useful Post:
Old 02-16-2020, 10:45   #2 (permalink)
Member: 2120988
Thanks Meter: 25
thanks for info. good team
Old 02-20-2020, 06:02   #3 (permalink)
Member: 2487890
Thanks Meter: 72
I can not run client 1.5 with Windows 10 both 1909 and 1809, have you test it on Windows 10?
Old 02-20-2020, 06:23   #4 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,275
no any option available (check/upgrade/activate) what can i do now ?
Old 02-22-2020, 20:52   #5 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello!
It means that you don't need to do anything.
Do you have any problems with the clip?
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 02-24-2020, 15:52   #6 (permalink)
Member: 2894608
Thanks Meter: 3
I can not run client 1.5 with Windows 10, any solution???? Need help ASAP
The Following 3 Users Say Thank You to damir.smartbar For This Useful Post:
Old 03-07-2020, 03:58   #7 (permalink)
Member: 1287530
Thanks Meter: 3
The same problem ..I can not run client 1.5 with Windows 10
The Following 2 Users Say Thank You to bashar218 For This Useful Post:
Old 03-09-2020, 18:55   #8 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
We are currently checking the issue with Windows 10, please expect answer tomorrow (on Tuesday).
Thank you for your patience.
The Following 2 Users Say Thank You to xtc2clip For This Useful Post:
Old 04-03-2020, 21:04   #9 (permalink)
Member: 2952561
Unable to activate my clip on Windows 10 also...any news on this? The executable silently fails, my clip is effectively useless as I'm not able to perform any operations in the meantime, please advise
Build 1607 here, seems like it doesn't run on any of the older or newer builds
Old 04-05-2020, 16:16   #10 (permalink)
Member: 2191251
Thanks Meter: 3
Xtc clip 2 1.5 install error
Connection to server feiled. Connection timeout
plz help me
Old 04-05-2020, 20:09   #11 (permalink)
Member: 1159687
Connection to server failed. Connection timeout
please fix this error
and not working in windows 10 also
Old 04-06-2020, 17:44   #12 (permalink)
Member: 1868789
Same error -Connection to server failed. Connection timeout
Old 04-07-2020, 18:56   #13 (permalink)
Member: 1868789
Has anyone managed to solve the activation problem XTC clip????
Old 04-10-2020, 15:07   #14 (permalink)
Member: 2951890
The app doesn't run for me. I try to run as admin but it doesn't install.
Old 04-11-2020, 12:36   #15 (permalink)
Member: 1868789
On Windows 10, the program does not start, and while this issue is unresolved!!! XTC 2 Clip team disappeared somewhere
Page generated in 0.21007 seconds with 10 queries
