XTC 2 Client 1.5 - please upgrade to service your clips Dear customers, Should you need to check/upgrade/activate your XTC 2 Clip, please download latest version of XTC 2 Client v1.5 https://mega.nz/#!7pdVhKAS!8-Nln_Hpb...hdGbF3r03BzymE Please use version 1.5b if you have issues with Windows 8 or Windows 10: https://mega.nz/file/7h8zybpI#pkQukW...AvcSmAcyWB-0Zk Previous version 1.4 or older can no longer connect to the server. |
thanks for info. good team |
I can not run client 1.5 with Windows 10 both 1909 and 1809, have you test it on Windows 10? |
1 Attachment(s) no any option available (check/upgrade/activate) what can i do now ? http://forum.gsmhosting.com/vbb/atta...1&d=1582176173 |
It means that you don't need to do anything. Do you have any problems with the clip? |
I can not run client 1.5 with Windows 10, any solution???? Need help ASAP |
The same problem ..I can not run client 1.5 with Windows 10 |
Hello, We are currently checking the issue with Windows 10, please expect answer tomorrow (on Tuesday). Thank you for your patience. |
Unable to activate my clip on Windows 10 also...any news on this? The executable silently fails, my clip is effectively useless as I'm not able to perform any operations in the meantime, please advise Build 1607 here, seems like it doesn't run on any of the older or newer builds |
Xtc clip 2 1.5 install error Connection to server feiled. Connection timeout plz help me |
Connection to server failed. Connection timeout please fix this error and not working in windows 10 also |
Same error -Connection to server failed. Connection timeout |
Has anyone managed to solve the activation problem XTC clip???? |
The app doesn't run for me. I try to run as admin but it doesn't install. |
On Windows 10, the program does not start, and while this issue is unresolved!!! XTC 2 Clip team disappeared somewhere:mad: |
